How do I send data from Arduino to a Web Page using GSM ?
Hello Arduino fans. I'm just working on my big, big project for uni but i can't do it myself.
I have a project and Im using : Arduino Mkr Gsm1400 + Mkr Env Shield ( with sensors: TEMT6000, LPS22HD, VEM6065) + MKR Proto Shield. I also have sensors like Decagon EC-5, DS18B20 and SHT31 that i need to stick on the board.
Problem : I want to make my sensors that can measure :
  • soil's humidity (using Decagon EC-5),
    -measure soils's temperature ( using DS18B20),
  • measure air's humidity&temperature ( using Sensirion SHT31). to send data to a web page.
    I want to check the web page and see in real time the data from the sensors.
    optional: I want to upload time and date
    The problem is that I don't really know how to do it, i need to use html,css, sql? I have no ideea and I really, really need some help !
So guys please if someone can or know how to do it , please help me (its really important for me).
if u have questions be sure to leave a comment about them and i will try to explain
@andrazzn
Your topic was Moved to it's current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Three days of deafening silence probably says a lot. You say you have got all this stuff for Arduino, but have you got something that receives the data via GSM and displays the result?
Probably not such a great option. That information should be available in real time at the destination. And why do you want a web page anyway?
Hello,
You can do it easily by following these steps:
  • Connect sensors to board on designated pins
  • Read sensors' data using their libraries, add delay between readings
  • Make a string combining all sensor data, better it could be HTTP POST request
  • On server receiving end aka, server. write a API endpoint (PHP/ASP.Net/NodeJS etc.) and process the sensors values sent via POST
  • Save the data in database
  • Show the data on a dynamic page (PHP/ASP.Net/NodeJS etc.) to display the data.
These steps are just to give you idea what you need know to complete your project. Hope this helps.
chall3ng3r:
Hello,
Thank you so much !!!
You're welcome :slight_smile:
@MSN, +1
Also their is a MySQL connector library for Arduino
