Greetings fellas.
I'm working on an SMD oriented project in Eagle with an atmega2560 at it's heart. This here is the wiring diagram for the 16mhz crystal:
I've worked plenty with these DIP crystals to know how to wire them. Now for the SMD crystals I see that the most abundant options available to us are these 4 pin ones that run 2 grounds and 2 crystal pins.
Crystal part
The question is how do you wire this one up? Can you skip the ground connection and just use the 2 crystal pins?
Or do I still need to have these grounds conencted?
Thanks for the help!
