Hi everybody,
in a programming thread an old adafruit motorshield V1.2 is used.
I tried to find a schematic for this motor-shield but I do not really understand the schematics I have found so far
The library for the old adafruit motorshield V1.2 seems to use a 74HC595 bitshift-register to drive the pins of the L293D. Again I do not really understand what the code is doing with the IO-pins.
So a much more practical approach than analysing is real IO-pin-switching HIGH-LOW.
And this is my question:
with a steppermotor connected to the outputs 1Y to 4Y of the L293D what will happen if the input-pins are switched on/off in random order?
Is it possible to switch the inputs 1A to 4A and EN1 / EN2, EN3/EN4 to any LOW-HIGH-combination on all input-pins without damaging the L293D-chip?
is it possible to damage the L293D-chip with an anallowed HIGH-LOW_combination or not?
best regards Stefan
