How make a delay in square wave ?
Guys, i make a code about two square waves, and i need that one of them with a delay. Both have a same duty cycle, and this code is this:
#include <TimerOne.h>
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
Timer1.initialize(10);
Timer1.pwm(9, 768);
Timer1.pwm(10,768);
So, i have two signals with 75% duty cycle, but starting in the same time. Anyone know how i can solve this?
Ps: Sorry for my bad english
I think this may be what you want. I can see 100KHZ on each pin, but don't have a scope and can't see the phasing. If I slow the frequency down I can see the 75% duty cycle.
//Square wave generator 100KHz
//two outputs 75% DutyCycle offset 270 degree
//Timer 1 PWM with ICR1 TOP end Mode 10
  pinMode(9, OUTPUT); //output A
  pinMode(10, OUTPUT); //output B
  TCCR1A = 0; //clear timer registers
  TCCR1B = 0;
  TCNT1 = 0;
  GTCCR |= 1 << PSRASY; //reset prescaler
  //ICR1 and Prescaler sets frequency
  //no prescaler .0625 us per count @ 16Mh
  //160 counts x .0625 = 10 us = 100Khz
  TCCR1B |= _BV(CS10); //no prescaler
  ICR1 = 80;//PWM mode counts up and back down for 160 counts
  OCR1A = 20; //Pin 9 match
  //output A set rising/clear falling
  //Rise at TCNT 20 upslope, High 120 counts, Fall at TCNT 20 downslope
  //75% Duty Cycle Pulse centered on TCNT 80. High 120 Low 40
  TCCR1A |= _BV(COM1A1) | _BV(COM1A0); //output A set rising/clear falling
  OCR1B = 60; //Pin 10 match
  //output B clear rising/set falling
  //Fall at TCNT 60 upslope, Low 40, Rise at TCNT 60 downslope
  //75% Duty Cycle Pulse centered on TCNT 0. High 120 Low 40
  TCCR1A |= _BV(COM1B1); //output B clear rising/set falling
  TCCR1B |= _BV(WGM13); //PWM mode with ICR1 Mode 10
  TCCR1A |= _BV(WGM11); //WGM13:WGM10 set 1010
void loop () {}
