Hello,
How should i start programming in arduino uno board here is code..
pinMode(13, OUTPUT);
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
the error is showing. how to blink led at 13 with different delay
There is no error in code.
That is communication problem between your arduino and computer.
Check your board and port is correct.
How to check communication problem?
here is device manager it is showing this
Try download and reinstall Arduino software again. Download from software link at top of this page.
I AM DOWNLOADING THIS
ARDUINO SOFTWARE
HOURLY BUILDS
Download a preview of the incoming release with the most updated features and bugfixes.
Windows
Mac OS X (Mac OSX Lion or later)
Linux 32 bit , Linux 64 bit , Linux ARM
Download an earlier version that is known to be stable such as 1.8.2, not the hourly build
what error are this ?
Arduino: 1.8.2 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xbf
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xbf
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xbf
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xbf
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xbf
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xbf
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xbf
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xbf
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xbf
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xbf
An error occurred while uploading the sketch
option enabled in File -> Preferences.
Which port have you got selected in the IDE ?
please help me how to do this??
As a first learner of ArduinoUNO under IBMPC-WIN8 and Arduino IDE 1.8.0, I followed steps:
Create a Foleder ArduinoUNO under my working drive.
Download IDE-1.8.0 and copied it under ArduinoUNO Folder.
Installed the Arduinno IDE-1.8. Package.
Connect the ArduinoUNo Board with IBMPC using the USB Cable. Check that buil-in LED(L)
and Power LED (ON) are ignited.
Checking the Virtual COM Port (VCOMX) assigned to the Arduino Board.
Device Manager ---> Ports ---> Arduino (COM3) ---> Update Driver Software... --->
Browse my computer for driver software ---> Let me pick from a list of device drivers on my
computer ---> Arduino Uno ---> Next
Execute the Arduino IDE Interface from the Applications Menu
In the IDE Interface select:
Tools ---> Port ---> COM3
Tools ---> Board ---> Arduino UNo
Create the prom LEDBlink.ino (save under ArduinoUno\LEDBlink).
In the IDE perform:
Sketch ---> Verify/Compile
In the interface, we will the message: Done compiling
Press RESET key on the Arduino Board
In the Arduino perform:
Sketch ---> Upload
In the IDE Interface, we will the see the message:
Done uplaoding
On the Arduino Board, we will a blinking L at 1-sec interval.
i have done showing this error...
Sketch uses 948 bytes (2%) of program storage space. Maximum is 32256 bytes.
Pls try the steps of #13 with another AduinoUNO. If there is still problem, try the steps with another PC. We must make put systematic attempts to isolate the faulty item (software or hardware).
Try another USB lead first.
there is led blinking and power led is also working what to do?
always when i plug usb led on boards i.e. smd and led at pin13 blink when i press reset it stop..why?
