Hi! I am still new to Arduino. I really need help for how to calculate the distance that the wheels that have traveled using two encoders. I have been reading many different tutorials about the encoders, but I am still really confused for how to approach it. So far I have two codes for the left side and right side of the wheels.
Left
//these pins can not be changed 2/3 are special pins
int encoderPin1 = 2;
int encoderPin2 = 6;
volatile int lastEncoded = 0;
volatile long encoderValue = 0;
long lastencoderValue = 0;
int lastMSB = 0;
int lastLSB = 0;
Serial.begin (9600);
pinMode(encoderPin1, INPUT);
pinMode(encoderPin2, INPUT);
digitalWrite(encoderPin1, HIGH); //turn pullup resistor on
digitalWrite(encoderPin2, HIGH); //turn pullup resistor on
//call updateEncoder() when any high/low changed seen
//on interrupt 0 (pin 2), or interrupt 1 (pin 3)
attachInterrupt(0, updateEncoder, CHANGE);
attachInterrupt(1, updateEncoder, CHANGE);
void loop(){
//Do stuff here
Serial.println(encoderValue);
delay(100); //just here to slow down the output, and show it will work even during a delay
void updateEncoder(){
int MSB = digitalRead(encoderPin1); //MSB = most significant bit
int LSB = digitalRead(encoderPin2); //LSB = least significant bit
int encoded = (MSB << 1) |LSB; //converting the 2 pin value to single number
int sum = (lastEncoded << 2) | encoded; //adding it to the previous encoded value
if(sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) encoderValue ++;
if(sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) encoderValue --;
lastEncoded = encoded; //store this value for next time
Right
int encoderPin1 = 3;
int encoderPin2 = 5;
int lastMSB = 0;
int lastLSB = 0;
void loop(){
//Do stuff here
Thank you very much
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
