I have a SparkFun RedBoard (Uno) that reads 4 analog inputs and scales them to output to 4 Sparkfun Qwiic HT16K33 displays.
The Arduino sketch (from Github) is displaying integers only.
I need channel A0 in the format: -40.0 to +40.0
Thanks. Marty
#include <Wire.h>
#include <SparkFun_Alphanumeric_Display.h>
// I²C addresses for Qwiic Alphanumeric Displays
const byte displayAddresses[4] = {0x70, 0x71, 0x72, 0x73};
// Create display objects for each address
HT16K33 displays[4];
// Analog pins for each display
const byte analogPins[4] = {A0, A1, A2, A3};
// Scaling parameters for each display
struct ScaleParams
float inMin; // Minimum input voltage
float inMax; // Maximum input voltage
float outMin; // Minimum output value
float outMax; // Maximum output value
char format[8]; // Format for display
// Scaling values for each display
ScaleParams scale[4] =
// A0 temp ext 0.1 ─► 0.9v displays -40.0 -> +40.0
// A1 humid ext 0.7 ─► 2.3v displays 10 -> 80
// A2 humid int 0.7 ─► 2.3v displays 10 -> 80
// A3 BAP 1.7 ─► 2.0v displays 900 -> 1100
// Display A0
{0.1, 0.9, -40.0, +40.0, "%+3d"},
// Display A1
{0.7, 2.3, 10, 80, "%3d"},
// Display A2
// Display A3
{1.5, 2.0, 900, 1100, "%3d"}
Wire.begin();
// Initialize each display
for (int i = 0; i < 4; i++)
displays[i].begin(displayAddresses[i]);
displays[i].setBrightness(0);
displays[i].clear();
displays[i].print(i+1);
delay(150);
float analogToVoltage(float analogVal)
return analogVal * (3.3 / 1023);
float analogVal = analogRead(analogPins[i]);
float voltage = analogToVoltage(analogVal);
// Map voltage to scaled output
float scaled = (voltage - scale[i].inMin) * (scale[i].outMax -
scale[i].outMin) / (scale[i].inMax - scale[i].inMin) + scale[i].outMin;
// Clamp output to min/max
//if (scaled < scale[i].outMin) scaled = scale[i].outMin;
//if (scaled > scale[i].outMax) scaled = scale[i].outMax;
char buffer[8];
snprintf(buffer, sizeof(buffer), scale[i].format, (int)scaled);
displays[i].print(buffer);
kmin
June 18, 2026, 3:14pm
2
marty_k:
(int)scaled);
Because of this. You convert it to integer.
Check my HT16K33 library, it has several dedicated print functions including:
bool displayFloat(float f, uint8_t decimals = 3)
bool displayFixedPoint1(float f) displays values -99.9 .. 999.9 with 1 decimal.
Arduino Library for HT16K33 4x7segment display
See this thread about sprintf() with float values.
https://forum.arduino.cc/t/sprintf-with-float-values/937562
It's not supported on the Uno and other 8 bit avr boards. Use dtostrf().
Wawa
June 18, 2026, 9:05pm
6
AnalogRead returns integers, so try this approach.
int rawValue = analogRead (A0);
float value = map (rawValue, 0, 1023, -400, 400) / 10;
or, shorter,
float value = map (analogRead(A0), 0, 1023, -400, 400) / 10;
1. UNO R3 is a unipolar ADC which means it cannot convert -ve DC voltage into biary bits.
2. Let us see how to convert the signal coming from ADC-Ch0 (A0) into floating form. Connect 3.3V pin with A0-pin by a jumper wire.
unsigned int y = analogRead(A0); //y ~= 675
float voltY = (5.0/1023.0) * y; // voltY ~= 3.3
Serial.println(voltY, 1); //shows: approx. 3.3V
Wawa
June 19, 2026, 10:33am
8
Let's not forget that the Uno R3 doesn't have an A/D that can reliably read voltages.
It's ratiometric A/D relies on the potentially unstanle USB supply voltage.
It is not clear to me what OP's project is or does.
Golam
If you red carefully (past tense of READ) , you would see there is no negative voltages.
0.1 -> 0.9v to display -40.0 ─► +40.0
Thanks for this but my displays are 14-segment, not 7.
As I undersrand OP, TO, and TP are synonyms.
J-M-L
June 19, 2026, 1:47pm
14
Wawa:
You get an integral if you do that - you won’t have one decimal. You need to divide by 10.0 to get the division to be performed as a float.
marty_k:
past tense of READ
Preterite is spelled read (but indeed pronounced “red”)
I hovered over the OP's avatar which produced the text then took a screen shot of the area of interest.
mikedb
June 19, 2026, 2:00pm
17
Thanks , does not work for me.
Must be a Mac Safari thing.
Handy for discovering other things:
You can just leave the number as an integer, expressed as tenths, and go through a rather convoluted process to print that as a decimal number.
int valueTenths = map (analogRead(A0), 0, 1023, -400, 400);
char buffer[8];
snprintf(buffer, sizeof(buffer), "%c%2d.%1d", (valueTenths < 0) ? '-' : '+', abs(valueTenths) / 10, abs(valueTenths) % 10);
Serial.println(buffer);
It gets a little more complicated if you want the +/- to immediately proceed the number instead of being in a fixed position, but dtostrf() presents a similar problem where it does not show the '+' character for positive numbers.
Wawa
June 19, 2026, 8:11pm
20
You can only get that resolution by first setting the A/D reference to 1.1volt.
analogReference(INTERNAL); // set Aref to 1V1
Then you must find the returned A/D values at 0V1 and 0V9 for your board and use them in the map() command.
Example:
if 0.1volt returns 110 and 0.9volt returns 920...
Serial.println (rawValue); // see what values you get
float value = map (rawValue, 110, 920, -400, 400) / 10.0; // convert to -40/+40 float
Wawa
June 19, 2026, 8:22pm
21
Correct.
Posted before the morning coffee.
Thanks for correcting me.
