How to change the offsets on an MPU6050
The code that I have downloaded for my sensor does seem to detect the sensor, and change the x, y and z angles when the sensor is rotated, but somewhat unreliably. Have found that the sensor is most likely uncalibrated and that the offsets will need to be changed. I found code that can give me the offsets that I need to change. I found this in the MPU6050 library on arduino, and this was the IMU_Zero example.
Any directions on where to go from here? Below I have the code I am using and the offsets that IMU_Zero gave me to change. Any instructions online are either kind of unclear at the moment. Thanks o/
#include<Wire.h>
const int MPU_addr=0x68;
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
int minVal=265;
int maxVal=402;
double x;
double y;
double z;
void setup(){
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B);
Wire.write(0);
Wire.endTransmission(true);
void loop(){
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true);
AcX=Wire.read()<<8|Wire.read();
AcY=Wire.read()<<8|Wire.read();
AcZ=Wire.read()<<8|Wire.read();
int xAng = map(AcX,minVal,maxVal,-90,90);
int yAng = map(AcY,minVal,maxVal,-90,90);
int zAng = map(AcZ,minVal,maxVal,-90,90);
x= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI);
y= RAD_TO_DEG * (atan2(-xAng, -zAng)+PI);
z= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
Serial.print("AngleX= ");
Serial.println(x);
Serial.print("AngleY= ");
Serial.println(y);
Serial.print("AngleZ= ");
Serial.println(z);
Serial.println("-----------------------------------------");
delay(400);
All consumer grade sensors are uncalibrated. For the MPU-6050, determine the gyro offsets by averaging a few hundred readings during startup, with the device held still. Subtract the averages from the raw data.
For the accelerometer, a six point calibration is usually satisfactory. Scroll down this tutorial for instructions.
By the way, this code is complete nonsense, but keeps coming up on this forum:
The following code is correct, and gives reasonably accurate Euler angles for tilt (pitch and roll):
// minimal MPU-6050 tilt and roll (sjr). Works with MPU-9250 too.
// works perfectly with GY-521, pitch and roll signs agree with arrows on sensor module 7/2019
// Tested with 3.3V eBay Pro Mini with no external pullups on I2C bus (worked with internal pullups)
// Add 4.7K pullup resistors to 3.3V if required. A4 = SDA, A5 = SCL
#include<Wire.h>
const int MPU_addr1 = 0x68;
float xa, ya, za, roll, pitch;
  Wire.begin();                                      //begin the wire communication
  Wire.beginTransmission(MPU_addr1);                 //begin, send the slave adress (in this case 68)
  Wire.write(0x6B);                                  //make the reset (place a 0 into the 6B register)
  Wire.write(0);
  Wire.endTransmission(true);                        //end the transmission
  Wire.write(0x3B);  //send starting register address, accelerometer high byte
  Wire.endTransmission(false); //restart for read
  Wire.requestFrom(MPU_addr1, 6); //get six bytes accelerometer data
  int t = Wire.read();
  xa = (t << 8) | Wire.read();
  t = Wire.read();
  ya = (t << 8) | Wire.read();
  t = Wire.read();
  za = (t << 8) | Wire.read();
// formula from https://wiki.dfrobot.com/How_to_Use_a_Three-Axis_Accelerometer_for_Tilt_Sensing
  roll = atan2(ya , za) * 180.0 / PI;
  pitch = atan2(-xa , sqrt(ya * ya + za * za)) * 180.0 / PI; //account for roll already applied
  Serial.print("roll = ");
  Serial.print(roll,1);
  Serial.print(", pitch = ");
  Serial.println(pitch,1);
  delay(400);
