How to implement MPU6050 offsets into code?
Hi. I am using an MPU6050 with an arduino uno for a project, and I am trying to calibrate it. I found a program by Jeff Rowberg which gave me offsets for each reading, but I don't know how to use them. The code says to "set them using something similar to mpu.setXAccelOffset(youroffset)". However, when I put this code into my program, I am getting errors. If I put it at the very beginning of the program, I get an error saying "'mpu' does not name a type". If I put it in the setup loop, I get an error saying "'mpu' was not declared in this scope". Does anybody know how I am supposed to use these offset values?
Here is a link to the code for getting the offsets:
// Arduino sketch that returns calibration offsets for MPU6050 //   Version 1.1  (31th January 2014)
// Done by Luis Ródenas <luisrodenaslorda@gmail.com>
// Based on the I2Cdev library and previous work by Jeff Rowberg <jeff@rowberg.net>
// Updates (of the library) should (hopefully) always be available at https://github.com/jrowberg/i2cdevlib
// These offsets were meant to calibrate MPU6050's internal DMP, but can be also useful for reading sensors.
// The effect of temperature has not been taken into account so I can't promise that it will work if you
// calibrate indoors and then use it outdoors. Best is to calibrate and use at the same room temperature.
/* ==========  LICENSE  ==================================
 I2Cdev device library code is placed under the MIT license
 Copyright (c) 2011 Jeff Rowberg
 Permission is hereby granted, free of charge, to any person obtaining a copy
 of this software and associated documentation files (the "Software"), to deal
 in the Software without restriction, including without limitation the rights
 to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 copies of the Software, and to permit persons to whom the Software is
 furnished to do so, subject to the following conditions:
 The above copyright notice and this permission notice shall be included in
 all copies or substantial portions of the Software.
 THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 THE SOFTWARE.
// I2Cdev and MPU6050 must be installed as libraries
#include "I2Cdev.h"
#include "MPU6050.h"
#include "Wire.h"
///////////////////////////////////   CONFIGURATION   /////////////////////////////
//Change this 3 variables if you want to fine tune the skecth to your needs.
int buffersize=1000;     //Amount of readings used to average, make it higher to get more precision but sketch will be slower  (default:1000)
int acel_deadzone=8;     //Acelerometer error allowed, make it lower to get more precision, but sketch may not converge  (default:8)
int giro_deadzone=1;     //Giro error allowed, make it lower to get more precision, but sketch may not converge  (default:1)
// default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
//MPU6050 accelgyro;
MPU6050 accelgyro(0x68); // <-- use for AD0 high
int16_t ax, ay, az,gx, gy, gz;
int mean_ax,mean_ay,mean_az,mean_gx,mean_gy,mean_gz,state=0;
int ax_offset,ay_offset,az_offset,gx_offset,gy_offset,gz_offset;
///////////////////////////////////   SETUP   ////////////////////////////////////
  // join I2C bus (I2Cdev library doesn't do this automatically)
  Wire.begin();
  // COMMENT NEXT LINE IF YOU ARE USING ARDUINO DUE
  TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz). Leonardo measured 250kHz.
  // initialize serial communication
  // initialize device
  accelgyro.initialize();
  // wait for ready
  while (Serial.available() && Serial.read()); // empty buffer
  while (!Serial.available()){
    Serial.println(F("Send any character to start sketch.\n"));
    delay(1500);
  while (Serial.available() && Serial.read()); // empty buffer again
  // start message
  Serial.println("\nMPU6050 Calibration Sketch");
  delay(2000);
  Serial.println("\nYour MPU6050 should be placed in horizontal position, with package letters facing up. \nDon't touch it until you see a finish message.\n");
  delay(3000);
  // verify connection
  Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
  // reset offsets
  accelgyro.setXAccelOffset(0);
  accelgyro.setYAccelOffset(0);
  accelgyro.setZAccelOffset(0);
  accelgyro.setXGyroOffset(0);
  accelgyro.setYGyroOffset(0);
  accelgyro.setZGyroOffset(0);
///////////////////////////////////   LOOP   ////////////////////////////////////
  if (state==0){
    Serial.println("\nReading sensors for first time...");
    meansensors();
    state++;
  if (state==1) {
    Serial.println("\nCalculating offsets...");
    calibration();
    state++;
  if (state==2) {
    meansensors();
    Serial.println("\nFINISHED!");
    Serial.print("\nSensor readings with offsets:\t");
    Serial.print(mean_ax);
    Serial.print("\t");
    Serial.print(mean_ay);
    Serial.print("\t");
    Serial.print(mean_az);
    Serial.print("\t");
    Serial.print(mean_gx);
    Serial.print("\t");
    Serial.print(mean_gy);
    Serial.print("\t");
    Serial.println(mean_gz);
    Serial.print("Your offsets:\t");
    Serial.print(ax_offset);
    Serial.print("\t");
    Serial.print(ay_offset);
    Serial.print("\t");
    Serial.print(az_offset);
    Serial.print("\t");
    Serial.print(gx_offset);
    Serial.print("\t");
    Serial.print(gy_offset);
    Serial.print("\t");
    Serial.println(gz_offset);
    Serial.println("\nData is printed as: acelX acelY acelZ giroX giroY giroZ");
    Serial.println("Check that your sensor readings are close to 0 0 16384 0 0 0");
    Serial.println("If calibration was succesful write down your offsets so you can set them in your projects using something similar to mpu.setXAccelOffset(youroffset)");
    while (1);
///////////////////////////////////   FUNCTIONS   ////////////////////////////////////
void meansensors(){
  long i=0,buff_ax=0,buff_ay=0,buff_az=0,buff_gx=0,buff_gy=0,buff_gz=0;
  while (i<(buffersize+101)){
    // read raw accel/gyro measurements from device
    accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
    if (i>100 && i<=(buffersize+100)){ //First 100 measures are discarded
      buff_ax=buff_ax+ax;
      buff_ay=buff_ay+ay;
      buff_az=buff_az+az;
      buff_gx=buff_gx+gx;
      buff_gy=buff_gy+gy;
      buff_gz=buff_gz+gz;
    if (i==(buffersize+100)){
      mean_ax=buff_ax/buffersize;
      mean_ay=buff_ay/buffersize;
      mean_az=buff_az/buffersize;
      mean_gx=buff_gx/buffersize;
      mean_gy=buff_gy/buffersize;
      mean_gz=buff_gz/buffersize;
    i++;
    delay(2); //Needed so we don't get repeated measures
void calibration(){
  ax_offset=-mean_ax/8;
  ay_offset=-mean_ay/8;
  az_offset=(16384-mean_az)/8;
  gx_offset=-mean_gx/4;
  gy_offset=-mean_gy/4;
  gz_offset=-mean_gz/4;
  while (1){
    int ready=0;
    accelgyro.setXAccelOffset(ax_offset);
    accelgyro.setYAccelOffset(ay_offset);
    accelgyro.setZAccelOffset(az_offset);
    accelgyro.setXGyroOffset(gx_offset);
    accelgyro.setYGyroOffset(gy_offset);
    accelgyro.setZGyroOffset(gz_offset);
    meansensors();
    Serial.println("...");
    if (abs(mean_ax)<=acel_deadzone) ready++;
    else ax_offset=ax_offset-mean_ax/acel_deadzone;
    if (abs(mean_ay)<=acel_deadzone) ready++;
    else ay_offset=ay_offset-mean_ay/acel_deadzone;
    if (abs(16384-mean_az)<=acel_deadzone) ready++;
    else az_offset=az_offset+(16384-mean_az)/acel_deadzone;
    if (abs(mean_gx)<=giro_deadzone) ready++;
    else gx_offset=gx_offset-mean_gx/(giro_deadzone+1);
    if (abs(mean_gy)<=giro_deadzone) ready++;
    else gy_offset=gy_offset-mean_gy/(giro_deadzone+1);
    if (abs(mean_gz)<=giro_deadzone) ready++;
    else gz_offset=gz_offset-mean_gz/(giro_deadzone+1);
    if (ready==6) break;
Also, here is a picture of what the serial monitor is giving me after I run the code:
Thanks in advance.
It would help us to help you if you posted your code
Oh ok, I thought the link would be fine. I've added it to the question now.
Simply subtract the offsets from the raw gyro data. For example, replace the variables below with the numbers you get.
 gx = gx - gx_offset;
 gy = gy - gy_offset;
The offsets are the average values reported by the gyro when it is sitting still and should be reporting zero for the rate of rotation.
When I subtract the offsets, I'm still not getting zeros (or 16384 for accelZ (because of gravity)). Here is what I have added to my code. Do you know why I'm still not getting close to the right values?
accelX = Wire.read()<<8|Wire.read() + 1370;
  accelY = Wire.read()<<8|Wire.read() - 1878;
  accelZ = Wire.read()<<8|Wire.read() - 1283;
gyroX = Wire.read()<<8|Wire.read() - 129;
  gyroY = Wire.read()<<8|Wire.read() - 22;
  gyroZ = Wire.read()<<8|Wire.read() - 5;
This is what I am getting on the serial monitor:
Gyro X=-118 Y=-103 Z=-46 Accel X=1806 Y=-1874 Z=-1131
Gyro X=-673 Y=-91 Z=-18 Accel X=1958 Y=-1738 Z=-1039
Gyro X=-661 Y=-103 Z=-39 Accel X=1374 Y=-234 Z=-1059
Average offsets are not useful for calibrating the accelerometer. That part of the code you posted is complete nonsense.
For calibrating accelerometers a separate procedure is required. See Tutorial: How to calibrate a compass (and accelerometer) with Arduino | Underwater Arduino Data Loggers
To correct the gyro, simply calculate the average values of a couple of hundred gyro readings, with the sensor at rest, and use those values for offsets.
Do not use the following function calls (or do, but send zero values instead).
If you did make those function calls, the gyro offsets were probably being applied twice, which would explain the failure reported above.
I didn't use the accelgyro.setXGyroOffset() at all, I just subtracted the offsets. Should I have used the function instead?
If the gyro offsets were correctly calculated, then subtracted from subsequent raw gyro readings, the result should be close to zero on all three gyro axes.
Any other result is incorrect. However, the offsets are temperature dependent and will drift after a time.
Try something like this code, untested since I don't have that sensor.
// MPU-6050 Short Example Sketch
// Public Domain
#include<Wire.h>
const int MPU_addr = 0x68; // I2C address of the MPU-6050
int16_t AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ;
float gx = 0.0;  //gyro offsets
float gy = 0.0;
float gz = 0.0;
  Wire.begin();
  Wire.beginTransmission(MPU_addr);
  Wire.write(0x6B);  // PWR_MGMT_1 register
  Wire.write(0);     // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
  Serial.println("Keep sensor still until gyro offsets printed");
  delay(2000);
  // collect gyro data for calibration
  for (int i = 0; i < 500; i++) {
    Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
    Wire.endTransmission(false);
    Wire.requestFrom(MPU_addr, 14); // request a total of 14 registers
    AcX = Wire.read() << 8 | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
    AcY = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
    AcZ = Wire.read() << 8 | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
    Tmp = Wire.read() << 8 | Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
    GyX = Wire.read() << 8 | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
    GyY = Wire.read() << 8 | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
    GyZ = Wire.read() << 8 | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
    gx += GyX; gy += GyY; gz += GyZ;
  gx = gx / 500.0;
  gy = gy / 500.0;
  gz = gz / 500.0;
  Serial.print("Gyro offsets ");
  Serial.print(gx);
  Serial.print(", ");
  Serial.print(gy);
  Serial.print(", ");
  Serial.println(gz);
    Serial.println("corrected gyro values follow");
  Wire.requestFrom(MPU_addr, 14, true); // request a total of 14 registers
  Serial.print(GyX-gx);
  Serial.print(", ");
  Serial.print(GyY-gy);
  Serial.print(", ");
  Serial.println(GyZ-gz);
  delay(200);
I am still not getting close to zero values when I use this code. Do you know how I might fix this? I'm now trying to use the accelgyro.setXAccelOffset(accelXOffset);, but its not working? I am getting an error which says "accelgyro" was not declared in this scope. Any ideas what might cause this error?
Post examples of the output from the code in post #8.
Keep in mind that the MPU6050 is long obsolete, has not been manufactured for several years, and anything you buy today is almost certainly a clone or counterfeit, and probably won't meet the original specifications.
Here's what I'm getting as an output:
0.21, -2.71, 4.41
-0.79, -0.71, 4.41
1.21, 2.29, 2.41
-1.79, 8.29, -4.59
Maybe you're right, the problem is just error from the sensor itself.
That is normal device noise, and close to zero.
Oh, I guess I'm okay then. Thanks a lot for the help.
