How to change the frequency from 16 MHZ to 8MHZ in the MCP2515.cpp attached here ?
Thanks
Adam
/* Copyright (c) 2007 Fabian Greif
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS "AS IS" AND
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
* SUCH DAMAGE.
#include <avr/io.h>
#include <util/delay.h>
#if ARDUINO>=100
#include <Arduino.h> // Arduino 1.0
#else
#include <Wprogram.h> // Arduino 0022
#endif
#include <stdint.h>
#include <avr/pgmspace.h>
#include "global.h"
#include "mcp2515.h"
#include "mcp2515_defs.h"
#include "defaults.h"
// Schreibt/liest ein Byte ueber den Hardware SPI Bus
uint8_t spi_putc( uint8_t data )
// put byte in send-buffer
SPDR = data;
// wait until byte was send
while( !( SPSR & (1<<SPIF) ) )
return SPDR;
void mcp2515_write_register( uint8_t adress, uint8_t data )
RESET(MCP2515_CS);
spi_putc(SPI_WRITE);
spi_putc(adress);
spi_putc(data);
SET(MCP2515_CS);
uint8_t mcp2515_read_register(uint8_t adress)
uint8_t data;
RESET(MCP2515_CS);
spi_putc(SPI_READ);
spi_putc(adress);
data = spi_putc(0xff);
SET(MCP2515_CS);
return data;
void mcp2515_bit_modify(uint8_t adress, uint8_t mask, uint8_t data)
RESET(MCP2515_CS);
spi_putc(SPI_BIT_MODIFY);
spi_putc(adress);
spi_putc(mask);
spi_putc(data);
SET(MCP2515_CS);
uint8_t mcp2515_read_status(uint8_t type)
uint8_t data;
RESET(MCP2515_CS);
spi_putc(type);
SET(MCP2515_CS);
return data;
uint8_t mcp2515_init(uint8_t speed)
SET(MCP2515_CS);
SET_OUTPUT(MCP2515_CS);
RESET(P_SCK);
RESET(P_MOSI);
RESET(P_MISO);
SET_OUTPUT(P_SCK);
SET_OUTPUT(P_MOSI);
SET_INPUT(P_MISO);
SET_INPUT(MCP2515_INT);
SET(MCP2515_INT);
// active SPI master interface
SPCR = (1<<SPE)|(1<<MSTR) | (0<<SPR1)|(1<<SPR0);
SPSR = 0;
// reset MCP2515 by software reset.
// After this he is in configuration mode.
RESET(MCP2515_CS);
spi_putc(SPI_RESET);
SET(MCP2515_CS);
// wait a little bit until the MCP2515 has restarted
_delay_us(10);
// load CNF1..3 Register
RESET(MCP2515_CS);
spi_putc(CNF3);
/* spi_putc((1<<PHSEG21)); // Bitrate 125 kbps at 16 MHz
spi_putc((1<<BTLMODE)|(1<<PHSEG11));
spi_putc((1<<BRP2)|(1<<BRP1)|(1<<BRP0));
spi_putc((1<<PHSEG21)); // Bitrate 250 kbps at 16 MHz
spi_putc((1<<BRP1)|(1<<BRP0));
//spi_putc(1<<BRP0);
spi_putc(speed);
// activate interrupts
spi_putc((1<<RX1IE)|(1<<RX0IE));
SET(MCP2515_CS);
// test if we could read back the value => is the chip accessible?
if (mcp2515_read_register(CNF1) != speed) {
SET(LED2_HIGH);
return false;
// deaktivate the RXnBF Pins (High Impedance State)
mcp2515_write_register(BFPCTRL, 0);
// set TXnRTS as inputs
mcp2515_write_register(TXRTSCTRL, 0);
// turn off filters => receive any message
mcp2515_write_register(RXB0CTRL, (1<<RXM1)|(1<<RXM0));
mcp2515_write_register(RXB1CTRL, (1<<RXM1)|(1<<RXM0));
// reset device to normal mode
mcp2515_write_register(CANCTRL, 0);
// SET(LED2_HIGH);
return true;
// check if there are any new messages waiting
uint8_t mcp2515_check_message(void) {
return (!IS_SET(MCP2515_INT));
// check if there is a free buffer to send messages
uint8_t mcp2515_check_free_buffer(void)
uint8_t status = mcp2515_read_status(SPI_READ_STATUS);
if ((status & 0x54) == 0x54) {
// all buffers used
return false;
return true;
uint8_t mcp2515_get_message(tCAN *message)
// read status
uint8_t status = mcp2515_read_status(SPI_RX_STATUS);
uint8_t addr;
uint8_t t;
if (bit_is_set(status,6)) {
// message in buffer 0
addr = SPI_READ_RX;
else if (bit_is_set(status,7)) {
// message in buffer 1
addr = SPI_READ_RX | 0x04;
else {
// Error: no message available
return 0;
RESET(MCP2515_CS);
spi_putc(addr);
// read id
message->id = (uint16_t) spi_putc(0xff) << 3;
message->id |= spi_putc(0xff) >> 5;
spi_putc(0xff);
spi_putc(0xff);
// read DLC
uint8_t length = spi_putc(0xff) & 0x0f;
message->header.length = length;
message->header.rtr = (bit_is_set(status, 3)) ? 1 : 0;
// read data
for (t=0;t<length;t++) {
message->data[t] = spi_putc(0xff);
SET(MCP2515_CS);
// clear interrupt flag
if (bit_is_set(status, 6)) {
mcp2515_bit_modify(CANINTF, (1<<RX0IF), 0);
else {
mcp2515_bit_modify(CANINTF, (1<<RX1IF), 0);
return (status & 0x07) + 1;
uint8_t mcp2515_send_message(tCAN *message)
/* Statusbyte:
* Bit Function
* 2 TXB0CNTRL.TXREQ
* 4 TXB1CNTRL.TXREQ
* 6 TXB2CNTRL.TXREQ
uint8_t address;
uint8_t t;
// SET(LED2_HIGH);
if (bit_is_clear(status, 2)) {
address = 0x00;
else if (bit_is_clear(status, 4)) {
address = 0x02;
else if (bit_is_clear(status, 6)) {
address = 0x04;
else {
// all buffer used => could not send message
return 0;
RESET(MCP2515_CS);
spi_putc(SPI_WRITE_TX | address);
spi_putc(message->id >> 3);
spi_putc(message->id << 5);
spi_putc(0);
spi_putc(0);
uint8_t length = message->header.length & 0x0f;
if (message->header.rtr) {
// a rtr-frame has a length, but contains no data
spi_putc((1<<RTR) | length);
else {
// set message length
spi_putc(length);
// data
spi_putc(message->data[t]);
SET(MCP2515_CS);
_delay_us(1);
// send message
RESET(MCP2515_CS);
address = (address == 0) ? 1 : address;
spi_putc(SPI_RTS | address);
SET(MCP2515_CS);
return address;
