How to clone grbl axis to drive dual stepper motors
hi all
im working on my diy cnc and im using arduino uno and GRBL running on it with easydriver 4.4 i prefer to use dual steppers on y axis drive . but the problem im facing is i dont have the same output pin to control two stepper with same movement
here is my question
can i use the same step and direction pin from arduino to split in two and get same movement of stepper?
or do i have to edit the cpu_map file to appoint new pins ?
the second problem is if i edit the cpu _map file i cant use the arduino UNO since all ports have been declared , the next option would be arduino mega 2560
i tried editing the cpu_map fill for MEGA can some one tell me if this alterations will work or destroy my steppers n other circuitry? thanks
#ifdef GRBL_PLATFORM
#error "cpu_map already defined: GRBL_PLATFORM=" GRBL_PLATFORM
#endif
#define GRBL_PLATFORM "Atmega2560"
// Serial port pins
#define SERIAL_RX USART0_RX_vect
#define SERIAL_UDRE USART0_UDRE_vect
// Increase Buffers to make use of extra SRAM
//#define RX_BUFFER_SIZE		256
//#define TX_BUFFER_SIZE		128
//#define BLOCK_BUFFER_SIZE	36
//#define LINE_BUFFER_SIZE	100
// Define step pulse output pins. NOTE: All step bit pins must be on the same port.
#define STEP_DDR      DDRA
#define STEP_PORT     PORTA
#define STEP_PIN      PINA
#define X_STEP_BIT    2 // MEGA2560 Digital Pin 24
#define Y_STEP_BIT    3 // MEGA2560 Digital Pin 25
#define Z_STEP_BIT    4 // MEGA2560 Digital Pin 26
#define Y_STEP_BIT   5 // MEGA2560 Digital pin 27
#define STEP_MASK ((1<<X_STEP_BIT)|(1<<Y_STEP_BIT)|(1<<Z_STEP_BIT)) // All step bits
// Define step direction output pins. NOTE: All direction pins must be on the same port.
#define DIRECTION_DDR     DDRC
#define DIRECTION_PORT    PORTC
#define DIRECTION_PIN     PINC
#define X_DIRECTION_BIT   7 // MEGA2560 Digital Pin 30
#define Y_DIRECTION_BIT   6 // MEGA2560 Digital Pin 31
#define Z_DIRECTION_BIT   5 // MEGA2560 Digital Pin 32
#define y_DIRECTION_BIT  3 // MEGA2560 Digital Pin 32
#define DIRECTION_MASK ((1<<X_DIRECTION_BIT)|(1<<Y_DIRECTION_BIT)|(1<<Z_DIRECTION_BIT)) // All direction bits
// Define stepper driver enable/disable output pin.
#define STEPPERS_DISABLE_DDR   DDRB
#define STEPPERS_DISABLE_PORT  PORTB
#define STEPPERS_DISABLE_BIT   7 // MEGA2560 Digital Pin 13
#define STEPPERS_DISABLE_MASK (1<<STEPPERS_DISABLE_BIT)
// Define homing/hard limit switch input pins and limit interrupt vectors.
// NOTE: All limit bit pins must be on the same port
#define LIMIT_DDR       DDRB
#define LIMIT_PORT      PORTB
#define LIMIT_PIN       PINB
#define X_LIMIT_BIT     4 // MEGA2560 Digital Pin 10
#define Y_LIMIT_BIT     5 // MEGA2560 Digital Pin 11
#define Z_LIMIT_BIT     6 // MEGA2560 Digital Pin 12
#define LIMIT_INT       PCIE0  // Pin change interrupt enable pin
#define LIMIT_INT_vect  PCINT0_vect
#define LIMIT_PCMSK     PCMSK0 // Pin change interrupt register
#define LIMIT_MASK ((1<<X_LIMIT_BIT)|(1<<Y_LIMIT_BIT)|(1<<Z_LIMIT_BIT)) // All limit bits
// Define spindle enable and spindle direction output pins.
#define SPINDLE_ENABLE_DDR      DDRH
#define SPINDLE_ENABLE_PORT     PORTH
#define SPINDLE_ENABLE_BIT      3 // MEGA2560 Digital Pin 6
#define SPINDLE_DIRECTION_DDR   DDRE
#define SPINDLE_DIRECTION_PORT  PORTE
#define SPINDLE_DIRECTION_BIT   3 // MEGA2560 Digital Pin 5
// Define flood and mist coolant enable output pins.
// NOTE: Uno analog pins 4 and 5 are reserved for an i2c interface, and may be installed at
// a later date if flash and memory space allows.
#define COOLANT_FLOOD_DDR     DDRH
#define COOLANT_FLOOD_PORT    PORTH
#define COOLANT_FLOOD_BIT     5 // MEGA2560 Digital Pin 8
#ifdef ENABLE_M7 // Mist coolant disabled by default. See config.h to enable/disable.
#define COOLANT_MIST_DDR    DDRH
#define COOLANT_MIST_PORT   PORTH
#define COOLANT_MIST_BIT    6 // MEGA2560 Digital Pin 9
#endif
// Define user-control CONTROLs (cycle start, reset, feed hold) input pins.
// NOTE: All CONTROLs pins must be on the same port and not on a port with other input pins (limits).
#define CONTROL_DDR       DDRK
#define CONTROL_PIN       PINK
#define CONTROL_PORT      PORTK
#define RESET_BIT         0  // MEGA2560 Analog Pin 8
#define FEED_HOLD_BIT     1  // MEGA2560 Analog Pin 9
#define CYCLE_START_BIT   2  // MEGA2560 Analog Pin 10
#define SAFETY_DOOR_BIT   3  // MEGA2560 Analog Pin 11
#define CONTROL_INT       PCIE2  // Pin change interrupt enable pin
#define CONTROL_INT_vect  PCINT2_vect
#define CONTROL_PCMSK     PCMSK2 // Pin change interrupt register
#define CONTROL_MASK ((1<<RESET_BIT)|(1<<FEED_HOLD_BIT)|(1<<CYCLE_START_BIT)|(1<<SAFETY_DOOR_BIT))
#define CONTROL_INVERT_MASK CONTROL_MASK // May be re-defined to only invert certain control pins.
// Define probe switch input pin.
#define PROBE_DDR       DDRK
#define PROBE_PIN       PINK
#define PROBE_PORT      PORTK
#define PROBE_BIT       7  // MEGA2560 Analog Pin 15
#define PROBE_MASK      (1<<PROBE_BIT)
// Start of PWM & Stepper Enabled Spindle
#ifdef VARIABLE_SPINDLE
  // Advanced Configuration Below You should not need to touch these variables
  // Set Timer up to use TIMER4B which is attached to Digital Pin 7
  #define PWM_MAX_VALUE       65535.0
  #define TCCRA_REGISTER		TCCR4A
  #define TCCRB_REGISTER		TCCR4B
  #define OCR_REGISTER		OCR4B
  #define COMB_BIT			COM4B1
  #define WAVE0_REGISTER		WGM40
  #define WAVE1_REGISTER		WGM41
  #define WAVE2_REGISTER		WGM42
  #define WAVE3_REGISTER		WGM43
  #define SPINDLE_PWM_DDR		DDRH
  #define SPINDLE_PWM_PORT    PORTH
  #define SPINDLE_PWM_BIT		4 // MEGA2560 Digital Pin 97
#endif // End of VARIABLE_SPINDLE
I think it should work if you connect a pair of wires from each of the step and direction outputs on the Arduino to the step and direction inputs on the two stepper drivers. That way both drivers will get the same instructions.
This assumes that both motors need to rotate in the same direction. if not you will need to invert the direction signal for one driver.
...R
Robin2:
...R
No need to do that - swap the two wires of one winding will do the job.
Hi.every bary
Iam beginer.for made machin cnc what i do first.
MarkT:
Yes.
And just to be clear, @MarkT's comment just refers to the control of direction.
...R
thank you everyone for ur support !!!
Reza58:
Hi.every bary
The first thing to do is START YOUR OWN THREAD! Other wise you will probably be ignored.
Tell us what your CNC machine is going to do and how you intend to make it do that.
Paul
