Would anyone be able to help with the coding if I were to use the IR remote to start the EDF rather than the accelerometer? I'd still want to have the EDF turn off automatically with a variable timer
If no one here knows how to code, then I must be in the wrong place.
This is certainly the wrong place for someone with your attitude.
If you don't want to learn the way most people do, by starting at the beginning, and don't want to follow the directions on how to use this forum, post on the Gigs and Collaborations section of the forum, and be prepared to pay for the help.
Good luck with your project!
jremington:
This is certainly the wrong place for someone with your attitude.If you don't want to learn the way most people do, by starting at the beginning, and don't want to follow the directions on how to use this forum, post on the Gigs and Collaborations section of the forum, and be prepared to pay for the help.
Well it sure doesn't look like anyone is trying to help me from the beginning. I stated earlier, imagine explaining this to a 12 year old. Other than the math explained by one or two, there has been no useful info gained from this site.
I'm really not trying to be an a**hole. I simply do not understand anything about coding and simply asking for someone to help walk me through the process step by step
Starting from zero coding experience, it’s simply unrealistic to expect to be “walked through” doing a project of even this modest complexity. I know you don’t mean it, but you’re essentially asking someone to do it for you.
If you want to do this yourself (with help from the forum), you need to start at the very beginning. The Arduino IDE has many built-in examples that help you learn coding from the ground up. That’s the only way to do it. Otherwise, you will have to get someone to do it for you, especially if you want it done by this weekend.
Problem is the derby is this weekend and I'm having trouble learning how to code that quickly.
At this point your options are 1) find someone who understands this stuff to do it for you or 2) forget it.
Next time, start new projects earlier.
It's important to know things about actuators and sensors because they often have special requirements and impact firmware. An ESC, for example, may require a calibration procedure on start-up. Some are uni-directional, others bi-directional and they have different control requirements. Accelerometers have different interface requirements, different start-up requirements etc.
Here's what I wrote last night. It only samples the ADXL345 accelerometer I had on hand and provides a basic but untested scaffold for "an" ESC that may or may not be bidir and which may or may not require calibration. I was playing the idea of the accelerometer sensing "free fall" and trigging a flag to fire the EDF but ran out of time to develop it. You need to experiment with the whole thing, determine what the sensor does the moment the car is released and act on that. But not before...
#include <SparkFun_ADXL345.h>
#include <Servo.h>
#include <Wire.h>
const byte pinLED = LED_BUILTIN;
const byte pinESC = 9;
const byte pinAccelIRQ = 2;
#define ESC_MAX 179
#define ESC_CENTER 90
#define ESC_MIN 0
#define ESC_ZERO 0
#define ESC_POST_CAL_DLY 2500
#define NUM_CAL_STEPS 2
typedef struct
byte CalValue;
unsigned long CalDuration;
}StructESCCalibration;
//this assumes ESC is fwd only
//may need to add a step if ESC is fwd/rev with MAX (179), MIN (0) and CENTER (90)
StructESCCalibration ESCCalibration[] =
//full
.CalValue = ESC_MAX,
.CalDuration = 3000
//min
.CalValue = ESC_MIN,
.CalDuration = 3000
Servo
edf_esc;
ADXL345
accelerometer = ADXL345();
bool
bEDFEnable,
bFreeFall;
pinMode( pinLED, OUTPUT );
pinMode( pinESC, OUTPUT );
pinMode( pinAccelIRQ, INPUT );
bFreeFall = false; //flag set in ISR when free-fall detected
bEDFEnable = true; //ensures impulse occurs once
InitializeAccelerometer(); //set up the ADXL345
edf_esc.attach( pinESC ); //set up the ESC
//calibration required?
//comment out if not needed
//CalibrateESC(); //calibration may be required; eval required
}//setup
//accelerometer data is 13bit
// 0bfedc ba98 7654 3210
// 0bxxx1 1111 1111 1111
double
fAccels[3];
double
resultant;
unsigned int
x,y,z;
#if 0
accelerometer.readAccel(&x, &y, &z);
x>>=3;
y>>=3;
z>>=3;
Serial.print("X "); Serial.println(x,HEX);
Serial.print("Y "); Serial.println(y,HEX);
Serial.print("Z "); Serial.println(z,HEX);
accelerometer.get_Gxyz( fAccels );
Serial.print("X "); Serial.println(fAccels[0],2);
Serial.print("Y "); Serial.println(fAccels[1],2);
Serial.print("Z "); Serial.println(fAccels[2],2);
resultant = sqrt( pow(fAccels[0],2) + pow(fAccels[1],2) + pow(fAccels[2],2) );
Serial.print("Resultant "); Serial.println(resultant,3);
#endif
Serial.print(resultant);Serial.print(",");
Serial.print(fAccels[0]);Serial.print(",");
Serial.print(fAccels[1]);Serial.print(",");
Serial.println(fAccels[2]);
//handlerAccelIRQ();
//if EDF is enabled and free-fall has been detected
if( bEDFEnable && bFreeFall )
//hit the motor for a second
EDFImpulse();
//then clear the enable and ISR flags
bEDFEnable = false;
bFreeFall = false;
}//if
delay(10);
}//loop
void EDFImpulse( void )
digitalWrite( pinLED, HIGH );
edf_esc.write( ESC_MAX );
edf_esc.write( ESC_MIN );
digitalWrite( pinLED, LOW );
}//EDFImpulse
void CalibrateESC( void )
//if ESC calibration is required, this might work
//may not be necessary if ESC can be programmed with calibration prior to use here
for( int i=0; i<NUM_CAL_STEPS; i++ )
edf_esc.write( ESCCalibration[i].CalValue );
delay( ESCCalibration[i].CalDuration );
}//for
edf_esc.write( ESC_ZERO );
delay( ESC_POST_CAL_DLY );
}//CalibrateESC
void InitializeAccelerometer( void )
accelerometer.powerOn();
accelerometer.setRangeSetting(2);
accelerometer.setActivityXYZ(1, 1, 1); // Set to activate movement detection in the axes "adxl.setActivityXYZ(X, Y, Z);" (1 == ON, 0 == OFF)
accelerometer.setActivityThreshold(75); // 62.5mg per increment // Set activity // Inactivity thresholds (0-255)
accelerometer.setInactivityXYZ(0, 0, 0);
accelerometer.setTapDetectionOnXYZ(0, 0, 0);
// Set values for what is considered FREE FALL (0-255)
accelerometer.setFreeFallThreshold(5); // (5 - 9) recommended - 62.5mg per increment
accelerometer.setFreeFallDuration(30); // (20 - 70) recommended - 5ms per increment
// Turn on Interrupts for each mode (1 == ON, 0 == OFF)
accelerometer.InactivityINT(0);
accelerometer.ActivityINT(0); //may need to try this one too.
accelerometer.FreeFallINT(1);
accelerometer.doubleTapINT(0);
accelerometer.singleTapINT(0);
attachInterrupt( digitalPinToInterrupt(pinAccelIRQ), handlerAccelIRQ, RISING ); // Attach Interrupt
}//InitializeAccelerometer
//ISR for ADXL345. All we look for is the free-fall detect
void handlerAccelIRQ( void )
byte
intSrc;
//get the source
intSrc = accelerometer.getInterruptSource();
//if free-fall, set the flag for loop
if( accelerometer.triggered( intSrc, ADXL345_FREE_FALL ) )
Serial.println("Got here" );
bFreeFall = true;
}//handlerAccelIRQ
gfvalvo:
Starting from zero coding experience, it’s simply unrealistic to expect to be “walked through” doing a project of even this modest complexity. I know you don’t mean it, but you’re essentially asking someone to do it for you.If you want to do this yourself (with help from the forum), you need to start at the very beginning. The Arduino IDE has many built-in examples that help you learn coding from the ground up. That’s the only way to do it. Otherwise, you will have to get someone to do it for you, especially if you want it done by this weekend.
I have gone through a lot of the examples and youtube videos. Things have just not clicked for me. I don't know why it's not clicking for me.
yes I know I'm asking for someone to basically do it for me, I am asking for step by step instructions. I just thought someone on here would help me.
Step 1 - load up the Blink tutorial. Push it to your arduino. See the LED blink.
This confirms that you are able to push up a sketch and see the results.
Step 2 - change the blink tutorial code so that the LED blinks at a different rate. Push it to your arduino and see the different blink rate.
This confirms that you can change code successfully.
Steps 3 through 37 - try out other tutorials
Step 38 - change the sample code that came with your accelerometer, so that it records the various readings on to a memory card. Then put the project on to a derby car and make several runs, letting the arduino record the vibrations/g-force/freefall. Later, download that data on to a PC and see if you can identify which readings indicate the start of the race.
This will let you use those conditions as the trigger for your ESC run.
Edit: I suspect that a switch at the nose that detects when it is against the starting pin will be a much more repeatable trigger condition.
