SoftwareSerial esp01(2,3);
String readString;
Serial.println("testing serial comm");
esp01.begin(9600);
String msg = "led 1 is on ";
while(esp01.available()>0)
readString = esp01.readStringUntil('\n');
if(readString==msg)
{Serial.println("String : "+readString);
Have you verified that the software serial link works as expected?
yes everything is working fine except comparison of strings
You're not using strings, you're using Strings
will that work
can u give me the sketch
string is not any kewword i think
Neither is String.
What's your point?
What is connected to the other end of the software serial?
esp01 i am sending the code wait
#include "thingProperties.h"
int D0 = 0;
int D2 = 2;
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
pinMode(D0,OUTPUT);
pinMode(D2,OUTPUT);
ArduinoCloud.update();
// Your code here
Since Led is READ_WRITE variable, onLedChange() is
executed every time a new value is received from IoT Cloud.
void onLedChange() {
if(led ==HIGH)
{digitalWrite(D0,HIGH);
Serial.println(msg);
{digitalWrite(D0,LOW);
String msg = "led 1 is off ";
// Add your code here to act upon Led change
Since Led2 is READ_WRITE variable, onLed2Change() is
void onLed2Change() {
if(led2 ==1)
digitalWrite(2,HIGH);}
{digitalWrite(2,LOW);}
// Add your code here to act upon Led2 change
But, String is a data type. If int (a data type) is a keyword, then why is String not a keyword?
What do you see if you print readString in the monitor?
The list of C++ keywords is published.
Why not look it up?
If i print immediately after esp01.read, Serial monitor prints the string received from esp01 but when i compare that string with predefined msg string then nothing is printed.
It is not in the list.
So, String is not a keyword -- simple Y/N answer!!!
The first thing done in your compare is to see if the lengths are equal. I am guessing they are not. Print the sizeof() each string.
Good idea, i will try tomorrow and reply. Thanks
When you have the lengths also try printing out character by character to see if you can find a difference.
How to do that
Print the HEX of each character.
Better still, print the length of the String.
sizeof String will always be a constant, regardless of the length, typically six, for an AVR, IIRC.
