I have a motor that is controlled by an H-bridge driver. The driver is on the motherboard and the motor is on another PCB. I want to add an LED to this "other PCB", not the motherboard, to show when the motor is on. How would I go about this since the polarity of the wires can be switched depending on direction of motor?
Do I just add two LEDs in reverse of each other and one or the other will light up depending on direction? Or is it possible to add a single LED?
You could connect a single led via a diode bridge.
Another possibility is a 2-pin bi-colour led. These are two leds back-to-back in the same package. This would have the advantage of indicating the motor direction.
So looking at this datasheet of a bidirectional led, can I just place two LEDs like this also side by side? Since single LEDs are easier to find and cheaper than bidirectional LEDs it seems.
