Hello,
I want to buy a terminal shield for a Nano. That is, every pin on the Nano is connected to a separate terminal block.
here's the shield;
I want to connect rainbow ribbon cable (I think they are usually around 26-28 ga and are the one's used for dupont connectors) into these terminal blocks.
The opposite end of these wires will be female dupont connectors, which can connect to peripherals, e.g. sd card module.
A higher gauge will be needed for the power supply into the Arduino.
The problem is that these 26-28ga signal wires are so thin, that they don't clamp very well into the terminal blocks. the strands will also degrade over repeated insertion and removal, are prone to fraying and are just not very pleasant to use.
I use wire ferrules for larger gauge wire to solve this problem, which work great, but my ferrule crimper cannot work with wires thinner than 24 gauge.
Any ideas of how I can get a better connection with these small signal wires?
Thanks!
