How to control 4 separate servos at a time using Arduino UNO
Hi, Everyone I am B.S.S.SRIKAR
I have a plan to make a robot which 4 servo
but I don't know how 1 Arduino Uno can control 4 servos in a way which is simple, Can anyone please me as soon as possible.
Thank You :grinning: :grinning:
Regards,
B.S.S.SRIKAR
Do you know how to control 1 servo ?
Do you know how to use an array ?
Could you declare an array of servos ?
What do you mean by "simple" ?
Simple?
Well, there may be various versions of that.
But consider this accessory board:
@Paul_B What is this board, I've never seen it.
Can you please tell me for what it is used...
But, it looks cool
@UKHeliBob I only know:
~what is simple
~How to control 1 servo visit my servo explanation video
I don't know
~how to use an array ?
~declaring an array of servos ?
It is used for any of a number of applications. It can control 16 PWM outputs to light LEDs or with proper switching FETs, control motors.
It can control up to 16 servos - that is what the 16 3-pin servo connectors are for.
You connect it to your UNO (not the best board for the purpose - a Nano is more appropriate) by the two I²C pins and using the corresponding library, set the timing for each of the servos. The UNO/ Nano does not have to do anything else; it can even go to sleep if it needed to.
Very cool, fairly cheap and makes the job pretty simple for up to 16 servos.
Oh ok Thank You :grinning: :grinning:
You sound very young but I was not impressed with how you controlled the servo in your video
  • an Arduino pin can only supply a limited amount of current
  • taking too much current from a pin may damage the Arduino
  • the battery used cannot supply enough current to run a Uno and a servo for very long
  • MalwareBytes says that the site you to linked to is a phishing risk
In what way do you want to control 4 servos ? What will control their positions ?
Yes, I am really young I am 10 years old and interested in Robotics from 3 years
I've learned these both from you
Yes one time Arduino didn't get sufficient amount of power and servo did not run on battery.
This is not true I think so...
I didn't get you, can you please explain me
Arduino will control their positions
Then you have done quite well so far
If the robot has 4 servos then what do you want them to do ?
1 servo is for right hand :raised_hand:
2nd servo is for left hand :raised_hand:
3rd servo is for moving the body at the hip
4th servo is to move the head acts as a neck
How do you want to control their positions ?
Possibly with potentiometers
If not, then how ?
I want to control their positions through smartphone :iphone: app (I know how to develop apps)
So, if the app can send a value between 0 and 180 do you know how to receive it, perhaps using Bluetooth ?
Yes, It send some value like ex
1801 for (180 degrees for servo1)
1002 for (100 degrees for servo2)
All these data is sent from our smartphone :iphone: via bluetooth
I suggest that you change what you send to make it easier to deal with. If you were to send say 1,123 for 123 degrees on servo 1 then it would be easy to parse out the 123, convert it to a byte and write it to servo 1
To make things even easier send the values with a start and end marker so that it looks like <1,123> That way it is much easier to deal with on the Arduino
Take a look at Serial input basics - updated for examples of receiving and parsing data
Thank You So much for this Idea
Also, for your initial testing, you can use Serial instead of Bluetooth - the parsing code will be the same. Indeed, you can get started without any servos hooked up.
If you send a string like <1,123> then it would be easy to parse the data and move servo 1 to angle 123
The UNO can control up to 12 servos. You control each servo the same way: Assign it a pin with servoName.attach(pin); Then call servoName.write(angle) to have the servo move to the specified angle (0 to 180).
