How To Control Water Flow?
I am trying to build a cute tiny water fountain that might require coding to control water flow.
I am using this tutorial (https://www.youtube.com/watch?v=EOnhLrAKLFo&list=PLbYnZIzA_AI65hGoL3DDUgnJV1lDfzWBE&index=59 ) and electronics to make that fountain. The thing is, I would like to have it detect the distance and control the water flow regarding the distance (e.g., the closer distance, the bigger flow). Any recommendation for a smarter water pump/tutorial/code is appreciated.
Hi, @Lita_Tieda
Welcome to the forum.
Put the ultra sonic unit in the base pointing up, so it detects the distance to the bottom of the container.
Good place to start.
Tom.. :smiley: :+1: :coffee: :australia:
I take that to mean that the distance here refers to the distance of a person to the water feature. In which case you need a distance sensor to detect how far some one is away from the water feature. I would use a TOF (time of flight) distance sensor to to this.
The thing about using an ultrasonic sensor with a water fountain is that a lot of ultrasonic noise is generated by falling water. Just try pointing a bat detector at a fountain to hear this noise.
