I would like to copy a file that is in the root folder of my Yun, to my Macbook. They are connected through ethernet cable and I am logged into the Yun through ssh.
The Yun's IP is 192.168.2.16 while the Mac's is 192.168.2.1.
How can I copy a file from the Yun? I know how to do the opposite with scp command but I don't know how to use it in this case
arjan_hes:
Would this also be possible with Putty in windows? I try to get the path right but it keeps saying no such file or directory.
A putty window is not the same thing as a Mac terminal window. Putty is a terminal emulator that can communicate with remote systems over serial ports or network ports. The Mac terminal is a command line window to the local system - the closest equivalent on Windows is a "cmd" window.
When mridolfi is typing the SCP command, he's telling the Mac to run that command and copy from the Yun to the local system. In that case, /where/you/want/it/to/go is the Mac's file name. Windows uses a very different syntax, something like c:\where\you\want\it
You might be able to do the same thing under Windows using a cmd window, after you find and install an SCP command line client on your computer. But there's an easier way: get WinSCP and then use that to connect to your Yun. It gives you a window to the Yun's file system, and lets you simply drag files in either direction.
I was sort of half half looking for this program. Last week I thought it might be a good idea to copy some file from my Yun as my webpage is nearing completion and it was a lot of effort. So I was thinking about 'a' program that looks like... well, winscp as it turns out. Thanks!
snottywong:
Install an SFTP server on the Yun, using these commands:
opkg update
opkg install openssh-sftp-server
Then use an SFTP client like Cyberduck or WinSCP to traverse the file structure of your Yun, drag and drop files into it, etc.
Traversing a file structure using text commands hasn't been necessary since the mid 80's.
Its not necesary to install that on yun to use winscp. I used it out if the box.
