I would like to do pin assignments by using an array.
So I'm looking for a way to and store the pin names in the array.
Example:
Ordinary code would look like this to assign pin A1 to a certain actor:
... #define actor2 A1; // actor 2 is connected to A1
digitalWrite(actor, HIGH);
I would like to use an array like this:
int nmbr_actors =8; // number of actors: 8
'string' actor_pin[nmbr_actors]; // an array containing the pin for each actor, identified by the actor number
actor_pin[2] = A1; // assigning pin A1 to actor 2
act_actor = 2; // actual actor to control is actor 2
digitalWrite(actor_pin[act_actor], HIGH);
The analog pin names, A0, A1, etc, are actually referring to numbers, so you would not treat them as strings.
In the case of A1, the following code is found in the pins_arduino.h file for the UNO/Nano:
#define PIN_A1 (15) // this defines PIN_A1 as the number 15
static const uint8_t A1 = PIN_A1; // this creates a constant named A1 and initializes it with the value of PIN_A1, which is 15
It may appear a bit convoluted, but the reason for doing it this way is that analog port A1 does not have the same numeric value on all Arduino boards.
