I want to connect my RS232 device (modem or even something else) to Arduino Mega 2560 R3. The device uses a standard serial communication with CTS/RTS handshake (or whatever it's properly called).
I plan to purchase RS232 - TTL converter, which contains all the required signals (see figure).
AVR / Arduino Serial class uses TX and RX pins (so it is USART only) and I'm interested in how to "add" CTS/RTS handshaking (wiring and programming).
Depending on the exact application, you may not even have to write a single piece of code and can just connect RTS to CTS to fool the device into thinking that your Arduino is always ready to accept new data.
The problem you may have is that if the device does not leave the minimum required inter byte delay, you may get some errors.
Also in some obscure devices, you may have to invert either CTS or RTS before connecting them together.
Worth a try.
The Arduino needs to use 2 extra pins one in and one out
The code below is not engineered but should give you the idea
uint8_t CTS = 4; // CLEAR TO SEND
uint8_t RTS = 5; // REQUEST TO SEND
if (digitalRead(RTS) == HIGH) // the PC want to send data
if (buffer is empty)
digitalWrite(CTS, HIGH); // allow sending of data
while (Serial.available() == 0) ; // wait for data to come in.
digitalWrite(CTS, LOW); // signal to stop sending data
process data from serial
a variation sometimes seen, (depends on the sending hardware
// give a pulse to signal send allow
delay(n); // n typical 1 or 2 milliseconds.
while (digitalRead(RTS) == HIGH); // wait for LOW. ==> CTS is recieved.
x = Serial.read();
K5CZ:
I do not want to fool the devices. I wand to
:LOOP
receive some batch of data, to disable receiving, processing data, to enable receiving
GOTO :LOOP
