How to externally power 12 mg996r servo motors
Hi. I wanted to supply power to my 12 mg996r servos using nimh batteries which are 7.2V and has a max discharge rate of 30A. These are the batteries https://www.amazon.com/dp/B07VLKP6RJ?psc=1&ref=ppx_yo2ov_dt_b_product_details. I have multiple of these batteries and I was wondering how I can use them to power the motor.
Can I just split up the 7.2V output and ground to all my servos? I was thinking of using my breadboard but I remember checking the specs and they recommend 5V 3A which is way below what I have. So I wasn't sure if it'll cause my board to burn.
My initial plan was to use a motor driver PCA9685 and supply external power using this battery but I read that it has max 6v now and it only supplies 10A per board.
Anyways, any suggestions or help is much appreciated
Here's the schematic of the driver PCA9685:
Servo power of a PCA9685 board has nothing to do with PCA9685 power.
Only PCA9685 ground and servo ground are shared.
Servo power (screw terminal) is only connected to the row of servo+ pinstrips, nothing else.
Check if the servos you use are 8.4volt tolerant (fully charged battery).
Another concern is the rather thin servo power/ground traces of a PCA9685 board.
You could beef them up with wires between the screw terminal and the pin strip rows.
PCA9685 power comes from the Arduino.
Leo..
Keep in mind that the MG996R draws the start/stall current of 2.5 A, every time is starts moving.
Breadboards are completely out of the question for servo power.
Interesting. The servos' max voltage is 7.2V so does this mean that I can't use these batteries for them? Or I suppose if I discharge them till it's safe it works? Also I did read that the 6V is the max for V+ but is that not the servo voltage? I assumed because it was right next to the power supply. Here's where I read about it pca9685 PWM 6 volts max?.
Sry bout the qs. Just wanted to make sure I don't burn anything.
Ok thanks for pointing that out. I was thinking it'll fry.
Can I supply power to them connecting the motors in parallel with a protoboard with beefy wire? I am mainly not sure of how to divide up the current between the properly.
“ Can I supply power to them connecting the motors in parallel with a protoboard with beefy wire? I am mainly not sure of how to divide up the current between the properly.”
Yes
You can use a BOOST/BUCK converter to keep the voltage at 6V but these servos can be used down as low as 4.5V.
Thank you so much! Lemme try the external part tomorrow.
For BOOST/BUCK converter I found the maximum output current seems to always be like 3A. Oh, can I just combine this with the wires to ensure that the servos get 3As all the time and won't suddenly get 20A or something?
There are converters that can supply more current.
You can use several lower current converters to supply several servos.
Common GNDs between the supplies and Arduino.
Thanks! I'll try this out. Just to summarize:
I should connect my power supply to a protoboard where have all my motors connected in parallel to the 7.2V and the ground of the power supply.
Here, I should have the converter in order to limit the current to 3A and keep the voltage in a safe range for the motors.
I suppose I shouldn't use resistors because it reduces the voltage. Anyways will report what happens
