I'm going to use TMP36 for meassuring temperature with my Arduino Uno, and i also have relay like the one attached as image.
I want the relay to turn on my AC heater when temperature decreases under 15 degree celcius.
Can someone help med how find that code?
system
December 6, 2019, 9:52am
3
You probably won't "find" the right code; here 's how to read the temperature sensor. Then just do an if / else based on the temperature and digitalWrite the relay control pin.
Thanks.
Bu where do i plase the "if/else digitalwrite" code inside TMP36 code?
Sorry... i'm really noob at this...
deg87
December 6, 2019, 10:21am
5
add to the tmp36 example code with an if statement. Post your code so it is easier to help
Okay. Can do that later to day.
I just meant where in TMP36 code i should place the code for if statement and the relay. Is there a specific order?
system
December 6, 2019, 10:26am
7
Bjerknez:
Have you had a dive into the linked code to try to follow it? (It's quite well commented...)
Where do you think it should go?
Bjerknez:
(Hint: You need to have got to the stage where you know what the Celsius temperature is.)
(We were all noobs once: how long you stay a noob depends on how much you try to do it yourself )
What do you guys think about this code?
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 5
int sensorPin=1
int relayPin=9
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
float Celcius=0;
float Fahrenheit=0;
void setup(void)
sensors.begin();
pinMode(9, OUTPUT)
pinMode(1, INPUT)
void loop(void)
sensors.requestTemperatures();
Celcius=sensors.getTempCByIndex(0);
Fahrenheit=sensors.toFahrenheit(Celcius);
Serial.print(" C ");
Serial.print(Celcius);
Serial.print(" F ");
Serial.println(Fahrenheit);
if (sensorPin > 18) {
digitalWrite(relayPin, LOW)
else (sensorPin < 14) {
digitalWrite(relayPin, HIGH)
I think you failed to read the instructions on how to post code and you are missing a closing } and the indentation is wrong but other than that it looks good.
if (sensorPin > 18) { You gave "sensorPin" the value 1.
How is it ever going to be greater than 18?
Wow!! I can't believe i did that with so little errors. Thanks
And i'm really sorry i forgot to read the code guidelines.
system
December 7, 2019, 8:47am
12
Bjerknez:
But according to the link I gave, that sensor is just a simple analog sensor:
int reading = analogRead(sensorPin);
.... not a:
... one.
I know. I changed the sensor to tmp36 and after a good our in my basement, i get it to work
I got an led light up when temperature got to 18 degrees. I now understand how to merge the code with other codes.
