Hi.
I seem to be able to flash everything correctly. All goes smooth as in the instructions.
BUT:
After successfully flashing the FW using the CCloader I can't get all related AT commands to work.
This was obviously the case before flashing, as this is a cloned module. I used AT+RENEW and +RESET and still the same.
One example of what is going on:
Before the flash AT+NAME would return HM-BL5 (not sure exactly) now the same command returns nothing at all. Even when I set it with AT+NAMEXXXXX. I get OK and when querying the name again, no reply.
I am trying to use this as an iBeacon.
All AT commands described here Instructables - make an iBeacon work and get confirmation, but the module still does not show up in ane iBeacon scan or before entering iBeacon mode as a btooth device.
also setting the name gets a confirmation but AT+NAME results in no reply at all, not showing up on any btooth scan either.
I even used the manufacturer's HMSoft updater and updated to the 540, 541 and 545 version and still getting the same. I tried different serial port comm apps too...
...just seems as if commands are received and set but for some reason it's not working and trying to query the settings returns nothing...
I do realize I have a clone of the original HM-10, but since the flashing went OK without a hitch, all the commands execute and get OK, my arduino uno works fine too, I am just stumped...
Do you guys think there's any point in trying a different approach or should I just give up and buy a new module from reputable seller?
(btw. I had no idea there was a whole clone industry for HM-10, only after it did not work I found out that it's actually pretty hard to find a genuine product... )
EDIT: After re re-flashing the latest fw ver. 546 from manufacturers website the module still soes not return any specific AT responses but it has for the first time showed up in an ibeacon scanner app. My iPhone also picked it up. Don't know how long it will last or if any reset later on will not break this again...
still... I would appreciate any help in figuring out this weird AT commands inconsistency.
