I have been trying to get the HC-05 / zs-040 to see other Bluetooth devices - from Arduino Nano.
See:
https://www.martyncurrey.com/connecting-2-arduinos-by-bluetooth-using-a-hc-05-and-a-hc-06-pair-bind-and-link/
I am using Arduino Nano :
Ard: BT:
+3.3V -> +Vcc
-Gnd -> Gnd-
+3.3V -> EN (go into AT Mode)
p10 -> (R1K) -> TX -> ( R2K -> -Gnd )
p11 -> RX
+3.3V -> p34 (go into FULL AT Mode)
But, even though, I am in AT Cmd Mode, it is Not in FULL AT Cmd Mode.
Some cmds like AT+INIT, AT+INQ, etc - do not work or respond.
EN enable pin is tied to the +3.3V source.
p34 is connected to +3.3V via soldered jumper wire to the breadboard.
And, I hold BT button on power-up.
BT LED blinks at 2sec hz.
See below :
https://www.martyncurrey.com/arduino-with-hc-05-bluetooth-module-at-mode/
Mini AT Cmd modes do work and reply :
AT+RMADD , AT+ROLE , AT_CMODE , AT-NAME , etc ...
But, AT-INIT, AT-INQ, AT-PAIR, AT-BIND, etc - do Not work / reply.
-- I also did connect the p34 to +3.3V via soldered jumper wire to the breadboard.
-- And, I hold BT button on power-up.
But, this does not help. I tested 2 HC-05 boards - still no luck.
Lost on this.
What am I missing ?
Can we assume you have looked at this?
Well, I listed that link in my comment ,
I stated that p34 was connected to +3.3V.
I also hold the BT button on power-up.
-- It blinks at about 2sec hz.
Do you have anything else in particular ?
Code used :
// : BT_HC05_Master_to_BT-KEYBOARD : //
Ard: BT:
+3.3V -> +Vcc
-Gnd -> Gnd-
p10 -> -> R1K -> TX -> R2K -> -Gnd
p11 -> RX
// - use menu: "old Bootloader Atmega328"
// Bluetooth-Devices : W10: DeviceManagerApp:Bluetooth: M7 : Properties:Details:BluetoothDeviceAddress
// Bluetooth-Keyboard : BT Address = 232F099F0001
#include <SoftwareSerial.h>
SoftwareSerial mySerial( 10 , 11 ); // RX, TX
Serial.println( "\r\n- BT_HC05_Master_to_BT-KEYBOARD - \r\n" );
pinMode( 9 , OUTPUT ); digitalWrite(9,LOW); digitalWrite(9,HIGH);
mySerial.begin( 38400 );
Serial.println("A> Enter AT commands: \n");
mySerial.write( "AT+NAME=John\r\n" );
mySerial.write( "AT+NAME?\r\n" );
mySerial.write( "AT+PSWD?\r\n" );
mySerial.write( "AT+RNAME?\r\n" );
mySerial.write( "AT+VERSION?\r\n" );
mySerial.write( "AT+ADDR?\r\n" );
mySerial.write( "AT+ROLE?\r\n" );
mySerial.write( "AT\r\n" );
Serial.println("");
Serial.println("B> connect to BT:KEYBOARD (232F0990001) ");
mySerial.write( "AT+RMAAD\r\n" );
mySerial.write( "AT+ROLE=1\r\n" );
mySerial.write( "AT+RESET\r\n" );
mySerial.write( "AT+CMODE=0\r\n" );
mySerial.write( "AT+INQM=0,5,9\r\n" );
mySerial.write( "AT+INIT\r\n" );
mySerial.write( "AT+INQ\r\n" );
mySerial.write( "AT+RNAME?232F,09,9F0001\r\n" );
mySerial.write( "AT+PAIR=232F,09,9F0001\r\n" );
mySerial.write( "AT+BIND=232F,09,9F0001\r\n" );
mySerial.write( "AT+CMODE=1\r\n" );
mySerial.write( "AT+LINK=232F,09,9F0001\r\n" );
Serial.println("\nAT");
Serial.println("");
if( mySerial.available() )
Serial.write( mySerial.read() );
if( Serial.available() )
mySerial.write( Serial.read() );
jlsilicon:
+3.3V -> +Vcc
May not be the cause of the problem, but clearly contrary to instructions, and therefore probably not a good idea.
Just tried tying BT Vcc->+5V.
-- No difference
Also used code : HC-05_02_38400
No difference.
Tried: AT+INQM, AT+INQ, AT-INIT, etc - no response
Tried AT+ cmds repeatedly , while holding BT button.
Such as :
AT+PSWD?
Result :
+PSWD:NO KEY OK
AT+INQ
Result :
(no response)
AT+PSWD=1234
Result:
FAIL
AT+VERSION?
+VERSION:hc05V2.3_1e OK
That link shows there is a great variation of software in the same board id when made by different companies. Does your board fit any if the boards that have limited capability?
jlsilicon:
+PSWD:NO KEY OK
I seem to recall that a recent thread had this and the conclusion was that the module was actually a BLE device.
Purchased from here :
https://www.aliexpress.us/item/3256807225418049.html
The chip looks like the same chip sold anywhere, even all through ebay.
AT+VERSION?
B> AT+NAME?
B> AT+VERSION?
B> AT+RMAAD
B> AT+ROLE=1
B> AT+RESET
B> AT+CMODE=0
B> AT+INQM=0,5,9
B> AT+INIT
B> AT+INQ
B> AT+RNAME?232F,09,9F0001
B> AT+PAIR=232F,09,9F0001
B> AT+BIND=232F,09,9F0001
B> AT+CMODE=1
B> AT+LINK=232F,09,9F0001
B> AT+RNAME?
AT
+NAME:HC-05
OK
OK
OK
FAIL
FAIL
-- AT+ Cmds (mini) working here : RMAAD , ROLE , RESET , CMODE , RNAME , VERSION
-- AT+ Cmds (full) ignored : INQM , INIT , INQ , PAIR , BIND , LINK
xfpd
April 20, 2025, 3:45pm
10
I read (I do not know) that full mode is entered if you power-on without holding the button/pin34, then after power-on hold the button/pin34 while entering AT mode commands.
I tried holding the button while entering the commands also.
Still No result
Photo of my test circuit :
+3.3V -> p34
I have it soldered there all along.
(Yellow wires next to the antenna - tied to EN-pin and +3.3V )
Tested Voltages :
arduino 3.3V pin => +3.26V
BT RX pin => +3.12V
BT pin34 => +3.26V
(and BT EN pin is connected to p34 + arduino 3.3V pin)
xfpd
April 20, 2025, 3:53pm
13
Pull the wire Put a SPST on the Pin34 wire. I think that is "holding the button."
BLE ?
AT+PSWD=123456
OK
AT+PSWD?
+PSWD:123456 OK
-- so now what ?
Can I still link as Master ?
I figured that.
How do I get to Full AT Cmds ?
AT+INQ ... etc still do not work.
Except :
AT+BIND?
+BIND=00:00:00:00:00:00
AT+STATE?
+STATE:PAIRABLE OK
xfpd
April 20, 2025, 4:33pm
17
martyncurry web site has them.
No. No Full AT Cmds - just Mini.
Power up : with EN pin loose NC => blinks at 2hz
I connect p34=3.3V / NC => blinks at 2hz
I connect EN=3.3V / NC => blinks at 2hz
mini AT Cmds , but no Full AT Cmds
Power-up with EN=3.3V => blinks at 1hz
p34 no => blinks at 2hz
I connect p34=3.3V => blinks at 2hz
Disconnect EN => blinks at 0.5Hz
HC-05 :
-- always replies to Mini AT cmds,
-- but always ignores Full AT cmds.
Blinking at 2hz / 1hz / 0.5hz - makes no difference.
Tried all combos of EN / p34 -> +3.3V / NC - at Power-up , and after.
-- no difference other than the blink rate.
I have run through these tests with (3) different Bluetooth modules now - all same results.
Actually, once these chips go into AT mode,
-- I can not bring them out.
Even Gnd to Key EN pin on Power-up - still in AT mode.
-- Maybe the pin34 has changed ?
xfpd
April 20, 2025, 6:18pm
19
Check continuity from the button to Pin 34.
Check voltages at the button pin when not pressed, and when pressed.
For reference:
jlsilicon:
123456 OK
That being a response suggests it is a BLE device. Kosher HC-05s have a four-digit password.
