How to format a (date) string
Hello folks,
I'm wondering what would be the best way to (convert and) format date information into a string for output?
e.g. with the help of char str[11] variable?
// format a date into a string with leading zeros (if needed) on nDay and nMonth.
int nDay = 8;
int nMonth = 4;
int nYear = 2025;
Serial.print("today is: ");
Serial.print(nDay);
Serial.print("-");
Serial.print(nMonth);
Serial.print("-");
Serial.print(nYear);
// expected output: [today is 08-04-2025]
// I know, the code is not doing that. It's just for demonstration
void loop () {
Any ideas or suggestions?
Thanks in advance
    int nDay = 8;
    int nMonth = 4;
    int nYear = 2025;
    char buffer[40];  //large enough to hold the output string
    snprintf(buffer, sizeof(buffer), "today is: %02d-%02d-%04d", nDay, nMonth, nYear);
    Serial.println(buffer);
I will leave you to research how the formatting works
Can You define good, better and the best?
Not sure what you mean by 'best way'. There are all sorts of libraries, examples, tutorials about the programers nemisis, dates.
I would look in the Arduino.cc HERE then search like THIS
NOTICE: bottom right, 16 libraries found. It looks to me like 4 to 6 might be of interest to you.
If I really have to answer your question, my answer would be:
good: it's working w/o any errors
better: it's working w/o errors, memory- and time efficient
the best: no further improvement possible.
But someone else might have different criteria.
I'm answering just for the fun of it.
Sweet.
I see I still can learn a lot more about C++.
That's the solution for me.
Thanks.
Thanks for the tip.
IMHO, its' more about string formatting than dates and times.
Not sure what your point is, anytime someone mentions date/time, it's 99% of the time about formatting it.
I hope you found an answer in all the informative posts.
