Good afternoon to everybody,
I have a question and hope that someone will kindly find out the solution...I will be very thankful of that!!!
I have an esp32 and want to program an interrupt for the acquisition of a signal from a sensor.
Until now, everything ok...but I am not able to generate it at 1kHz..I am pretty new in this field, do you think is possible?
To generate a 1kHz interrupt on the ESP32, you can use one of its hardware timers. First, initialize the desired timer (e.g., TIMER_0) with the preferred settings, such as the 1kHz frequency and interrupt service routine (ISR). Set the timer's alarm value to trigger the interrupt at the desired interval (e.g., 1ms). Within the ISR, perform the necessary tasks. This approach ensures precise timing without burdening the CPU. Remember to configure the timer's clock source appropriately, and enable the interrupt. Finally, integrate the timer into your code to take advantage of the 1kHz interrupt for your application.
