Hello guys,
So I've been struggling on this for a while. My goal is to create an alarm using the MKR 1010, by in the first time getting the local current time from SSID, and then comparing it to a JSON payload.
However, I cannot seem to get the payload right. I've tried a lot of things but none of them have worked.
Please bear with me, I'm quite new to coding !
Right now I do have a JSON payload which URL is http://hiddendomainname.com/post/json/json_playload.php.
It is structured as such :
Here's my code so far :
#include <SPI.h>
#include <WiFiNINA.h>
#include <WiFiUdp.h>
#include <ArduinoJson.h>
#include <ArduinoHttpClient.h>
int status = WL_IDLE_STATUS;
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
int setTime = 0;
int motorPin = 3;
char serverAddress[] = "hiddendomainname.com";
int port = 80;
WiFiClient wifi;
HttpClient client= HttpClient(wifi, serverAddress, port);
unsigned int localPort = 2390; // local port to listen for UDP packets
IPAddress timeServer(129, 6, 15, 28); // time.nist.gov NTP server
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
WiFiUDP Udp;
WiFiServer server(80);
pinMode(motorPin, OUTPUT);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
Serial.println("Connected to wifi");
printWifiStatus();
Serial.println("\nStarting connection to server...");
Udp.begin(localPort);
sendNTPpacket(timeServer); // send an NTP packet to a time server
// wait to see if a reply is available
if (Udp.parsePacket()) {
Serial.println("packet received");
// We've received a packet, read the data from it
Udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
//the timestamp starts at byte 40 of the received packet and is four bytes,
// or two words, long. First, esxtract the two words:
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
// combine the four bytes (two words) into a long integer
// this is NTP time (seconds since Jan 1 1900):
unsigned long secsSince1900 = highWord << 16 | lowWord;
Serial.print("Seconds since Jan 1 1900 = ");
Serial.println(secsSince1900);
// now convert NTP time into everyday time:
Serial.print("Unix time = ");
// Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
const unsigned long seventyYears = 2208988800UL;
// subtract seventy years:
unsigned long epoch = secsSince1900 - seventyYears;
// print Unix time:
Serial.println(epoch);
// print the hour, minute and second:
Serial.print("The UTC time is "); // UTC is the time at Greenwich Meridian (GMT)
Serial.print((epoch % 86400L) / 3600); // print the hour (86400 equals secs per day)
Serial.print(':');
if (((epoch % 3600) / 60) < 10) {
// In the first 10 minutes of each hour, we'll want a leading '0'
Serial.print('0');
Serial.println((epoch % 3600) / 60); // print the minute (3600 equals secs per minute)
WiFiClient client = server.available(); // listen for incoming clients
setTime = collect();
if (epoch == setTime)
digitalWrite(motorPin, HIGH); // activate the motor
if (collect() == 0)
digitalWrite(motorPin, LOW); // deactivate the motor
// wait 30 seconds before asking for the time again
delay(30000);
int collect() {
Serial.println("making GET request");
String request = "/post/json/json_payload.php"; //url of what we need on our server
client.beginRequest();
client.get(request);
client.endRequest();
// read the status code and body of the response
int statusCode = client.responseStatusCode();
String response = client.responseBody();
Serial.println(statusCode);
//Serial.println(response);
Serial.flush();
DynamicJsonDocument doc(450);
String json = response;
// Deserialize the JSON document
DeserializationError error = deserializeJson(doc, json);
// Test if parsing succeeds.
if (error) {
Serial.print(F("deserializeJson() failed: "));
Serial.println(error.c_str());
return (0);
int jsonId = doc["id"];
int jsonTime= doc["time"];
// Print values.
Serial.println(jsonId);
Serial.println(jsonTime);
return (jsonTime);
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress& address) {
//Serial.println("1");
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
//Serial.println("2");
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
//Serial.println("3");
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); //NTP requests are to port 123
//Serial.println("4");
Udp.write(packetBuffer, NTP_PACKET_SIZE);
//Serial.println("5");
Udp.endPacket();
//Serial.println("6");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
And the monitor writes :
Attempting to connect to SSID: FreeBox
Connected to wifi
SSID: FreeBox
IP Address: 192.168.0.19
signal strength (RSSI):-64 dBm
packet received
Seconds since Jan 1 1900 = 3843648666
Unix time = 1634659866
The UTC time is 16:11
making GET request
-3
Also the loop runs very slow (about 70 seconds instead of 30) and I don't know why, and that could be a problem.
Thanks in advance, my brain is really frying on this one... ![]()
