OldSteve:
There's no need "to get around an absent driver", or for porting code from one language/platform to another.
right, in this particular case - i just can use the opensource project.
But my confusion is about a more general question/situation:
what if there were no opensource project. What if i had only the source code from the manufacturer. How could i use it with arduino? or for what matters PIC?
here is a copy/paste the examples from the manufacturer's supplied examples:
* @file main.c
* @brief Simple RX with diagnostics example code
* This application waits for reception of a frame. After each frame received with a good CRC it reads some data provided by DW1000:
* - Diagnostics data (e.g. first path index, first path amplitude, channel impulse response, etc.). See dwt_rxdiag_t structure for more
* details on the data read.
* - Accumulator values around the first path.
* It also reads event counters (e.g. CRC good, CRC error, PHY header error, etc.) after any event, be it a good frame or an RX error. See
* dwt_deviceentcnts_t structure for more details on the counters read.
* @attention
* Copyright 2016 (c) Decawave Ltd, Dublin, Ireland.
* All rights reserved.
* @author Decawave
#include "deca_device_api.h"
#include "deca_regs.h"
#include "lcd.h"
#include "port.h"
/* Example application name and version to display on LCD screen. */
#define APP_NAME "RX DIAG v1.0"
/* Default communication configuration. We use here EVK1000's default mode (mode 3). */
static dwt_config_t config = {
2, /* Channel number. */
DWT_PRF_64M, /* Pulse repetition frequency. */
DWT_PLEN_1024, /* Preamble length. Used in TX only. */
DWT_PAC32, /* Preamble acquisition chunk size. Used in RX only. */
9, /* TX preamble code. Used in TX only. */
9, /* RX preamble code. Used in RX only. */
1, /* 0 to use standard SFD, 1 to use non-standard SFD. */
DWT_BR_110K, /* Data rate. */
DWT_PHRMODE_STD, /* PHY header mode. */
(1025 + 64 - 32) /* SFD timeout (preamble length + 1 + SFD length - PAC size). Used in RX only. */
/* Buffer to store received frame. See NOTE 1 below. */
#define FRAME_LEN_MAX 127
static uint8 rx_buffer[FRAME_LEN_MAX];
/* Hold copy of status register state here for reference, so reader can examine it at a breakpoint. */
static uint32 status_reg = 0;
/* Hold copy of frame length of frame received (if good), so reader can examine it at a breakpoint. */
static uint16 frame_len = 0;
/* Hold copy of event counters so that it can be examined at a debug breakpoint. */
static dwt_deviceentcnts_t event_cnt;
/* Hold copy of diagnostics data so that it can be examined at a debug breakpoint. */
static dwt_rxdiag_t rx_diag;
/* Hold copy of accumulator data so that it can be examined at a debug breakpoint. See NOTE 2. */
#define ACCUM_DATA_LEN (2 * 2 * (3 + 3) + 1)
static uint8 accum_data[ACCUM_DATA_LEN];
* Application entry point.
int main(void)
/* Start with board specific hardware init. */
peripherals_init();
/* Display application name on LCD. */
lcd_display_str(APP_NAME);
/* Reset and initialise DW1000. See NOTE 3 below.
* For initialisation, DW1000 clocks must be temporarily set to crystal speed. After initialisation SPI rate can be increased for optimum
* performance. */
reset_DW1000(); /* Target specific drive of RSTn line into DW1000 low for a period. */
spi_set_rate_low();
if (dwt_initialise(DWT_LOADUCODE) == DWT_ERROR)
lcd_display_str("INIT FAILED");
while (1)
spi_set_rate_high();
/* Configure DW1000. */
dwt_configure(&config);
/* Activate event counters. */
dwt_configeventcounters(1);
/* Loop forever receiving frames. */
while (1)
int i;
/* TESTING BREAKPOINT LOCATION #1 */
/* Clear local RX buffer, rx_diag structure and accumulator values to avoid having leftovers from previous receptions This is not necessary
* but is included here to aid reading the data for each new frame.
* This is a good place to put a breakpoint. Here (after first time through the loop) the local status register will be set for last event
* and if a good receive has happened the data buffer will have the data in it, and frame_len will be set to the length of the RX frame. All
* diagnostics data will also be available. */
for (i = 0 ; i < FRAME_LEN_MAX; i++ )
rx_buffer[i] = 0;
for (i = 0 ; i < ACCUM_DATA_LEN; i++ )
accum_data[i] = 0;
rx_diag.firstPath = 0;
rx_diag.firstPathAmp1 = 0;
rx_diag.firstPathAmp2 = 0;
rx_diag.firstPathAmp3 = 0;
rx_diag.maxGrowthCIR = 0;
rx_diag.rxPreamCount = 0;
rx_diag.maxNoise = 0;
rx_diag.stdNoise = 0;
/* Activate reception immediately. See NOTE 4 below. */
dwt_rxenable(DWT_START_RX_IMMEDIATE);
/* Poll until a frame is properly received or an error/timeout occurs. See NOTE 5 below.
* STATUS register is 5 bytes long but, as the event we are looking at is in the first byte of the register, we can use this simplest API
* function to access it. */
while (!((status_reg = dwt_read32bitreg(SYS_STATUS_ID)) & (SYS_STATUS_RXFCG | SYS_STATUS_ALL_RX_ERR)))
if (status_reg & SYS_STATUS_RXFCG)
/* Clear good RX frame event in the DW1000 status register. */
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_RXFCG);
/* A frame has been received, copy it to our local buffer. */
frame_len = dwt_read32bitreg(RX_FINFO_ID) & RX_FINFO_RXFL_MASK_1023;
if (frame_len <= FRAME_LEN_MAX)
dwt_readrxdata(rx_buffer, frame_len, 0);
/* Read diagnostics data. */
dwt_readdiagnostics(&rx_diag);
/* Read accumulator. See NOTES 2 and 6. */
uint16 fp_int = rx_diag.firstPath / 64;
dwt_readaccdata(accum_data, ACCUM_DATA_LEN, (fp_int - 2) * 4);
/* Clear RX error events in the DW1000 status register. */
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_ALL_RX_ERR);
/* Reset RX to properly reinitialise LDE operation. */
dwt_rxreset();
/* Read event counters. See NOTE 7. */
dwt_readeventcounters(&event_cnt);
