So, I bought an infrared LED and photodiode in a package from Radio Shack a while ago, and now that I've finally found them in my messy room again I can't seem to get them to work. I have a test circuit (no arduino involved yet) of 2 AAs, to a 330 ohm resistor, to a normal LED, to the photodiode, back to the AAs, and the LED lights only slightly dimmer than without the photodiode.
Then on another circuit I have 1 AA, to another 330 ohm, to the IR LED, back to the AA. Opening and closing this circuit pointing the LED to the photodiode doesn't seem to make any difference in the brightness of the normal LED.
Here are the specs on the back of the package word for word:
Detector (photo diode--clear package)
Standard T-1 3/4 package
Maximum Voltage and Currents
Reverse breakdown 60V
Foward voltage 1.2V@l F 1mA
Total power dissipation: 100mW
Peak sensitivity wavelength: 900nm
Spectral bandwidth range: 750 - 980nm
Angle of half sensitivity: ±80°
Emitter (tinted package)
Reverse voltage: 5V
Continuous foward current: 100mA
Foward voltage: 1.5V typ., 1.8V max @50 mA
Radiant power output: 75.5mW/sr (typical)
Wavelength at peak emission: 850nm
So yeah am I doing something wrong? I might be mixing up forward/reverse current (by the way they misspelled "forward" as "foward" on the package LOL :P), and yes I have checked and double-checked my wiring, everything is solid and connected + to anode - to cathode.
I CAN tell you that I'm pretty sure the problem lies with the emitter, because I hooked up another normal LED to it in series (running on 2 AAs and a 330 resistor) and they did not light. If I bypass the IR LED with a jumper, the normal LED lights just fine.
I suppose the emitter could be faulty, but could there be another problem? Thanks in advance!
