Hello,
I'm currently making an arduino based digital scale with a standard 5kg load cell, a hx711 amp, lcd display, and a few buttons for basic interface now already made that calibration code that stores values in EEPROM but after calibration the weight seems to drift around 1.2Grams over time(for around 2minutes stays there and then fluctuates around 0.03 grams +- how is it possible to fight this?
Thanks for helping here is the code so far:
#include "HX711.h"
#include <EEPROM.h>
#include <Wire.h>
#include <LiquidCrystal_PCF8574.h>
#define LCD_ADDRES 0x3F
#define HX711_DT_PIN A1
#define HX711_CLK_PIN A0
LiquidCrystal_PCF8574 lcd(LCD_ADDRES);
// HX711.DOUT - pin #A1
// HX711.PD_SCK - pin #A0
#define BUTTON0_PIN A2
HX711 scale(HX711_DT_PIN, HX711_CLK_PIN); // parameter "gain" is ommited; the default value 128 is used by the library
int error;
pinMode(BUTTON0_PIN, INPUT_PULLUP);
Wire.begin();
Wire.beginTransmission(0x3F);
error = Wire.endTransmission();
Serial.print("Error: ");
Serial.print(error);
if (error == 0) {
Serial.println(": LCD found.");
Serial.println(": LCD not found.");
} // if
lcd.begin(16, 2); // initialize the lcd
lcd.print("Hello LCD");
scaleCalibrate(100, 25);
bool Calibrated = EEPROM.read(0);
if(!Calibrated){
else {
float CalVal;
EEPROM.get(1, CalVal);
scale.set_scale(CalVal);
//scale.set_scale(2280.f);
lcd.clear();
while(true){
//lcd.setCursor(8,0);
float Weight = scale.get_units(5);
long RawVal = scale.read_average(5);
lcd.clear();
lcd.print("W: ");
lcd.print(Weight);
lcd.print(" grams");
lcd.setCursor(0,1);
lcd.print(RawVal);
scale.power_down(); // put the ADC in sleep mode
delay(2000);
scale.power_up();
long scaleCalibrate(float CalibrationWeight, int AvgTimes){
float CalVal;
long CalTareVal;
long PreCalVal;
lcd.clear();
lcd.print("Taring the scale please don't touch it");
delay(2000);
scale.tare();
lcd.clear();
lcd.print("Place the weight");
lcd.setCursor(0,1);
lcd.print("and press the button");
while(digitalRead(BUTTON0_PIN)!= 0);
lcd.clear();
lcd.print("Starting calibration!");
PreCalVal = scale.get_value(AvgTimes);
Serial.print("PreCalVal: ");
Serial.println(PreCalVal);
CalVal = float(PreCalVal) / float(CalibrationWeight);
Serial.print("CalVal: ");
Serial.println(CalVal);
lcd.clear();
lcd.print("Calibration Done!");
EEPROM.update(0, 1);
EEPROM.put(1, CalVal);
delay(2000);
