Hi, I'm trying to write a program which listens for UDP packets and transforms them into various string commands. I have Arduino Uno with an Ethernet shield.
My UDP broadcaster is a C# program which sends 25 packets per second via a timer.
Let's say I run my C# program for 4 seconds, which will result in 100 packets sent.
I've put a large delay at the end of the Arduino loop to simulate heavy processing of the incoming message and I've encountered a problem.
Arduino takes (X + 1000) ms to process a single packet, which means that while it processes the first packet, there are 24 more sent.
The problem is that after processing packet 1 it doesn't get the newest packet from the broadcast, instead it continues with processing packet 2.
My question is if there is any way to flush/delete all of the incoming UDP packets and just wait for the next one (or get the last incoming one)? This way I will be sure that the processed data is always a fresh string command.
My code is a standard EthernetUdp example, the only modifications I've made are the attached buzzer and the increased delay.
#include <SPI.h> // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 0, 199);
unsigned int localPort = 8888; // local port to listen on
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
char ReplyBuffer[] = "seen"; // a string to send back
EthernetUDP Udp;
Ethernet.begin(mac, ip);
Udp.begin(localPort);
pinMode(8, OUTPUT); // buzzer
digitalWrite(8, LOW);
int packetSize = Udp.parsePacket();
if (packetSize) {
digitalWrite(8, HIGH);
//DisplayInfo(packetSize);
// read the packet into packetBufffer
Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
Serial.println(packetBuffer);
// send a reply to the IP address and port that sent us the packet we received
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write(ReplyBuffer);
Udp.endPacket();
