How to get rid of goto statement?
This is my sketch (given below) where I have to use goto statement to reach at the back. I have been trying to get rid of the goto statement, but I am not yet successful! Any help would be appreciated.
#include<avr/sleep.h>
int brightness_SEL = 0;
  pinMode(2, INPUT_PULLUP);
  SMCR |= (1 << SM1); //Power-down Mode
  attachInterrupt(digitalPinToInterrupt(2), wakeISR, LOW);  //must be level mode
L1: unsigned long currentMillis = millis();
  while (millis() - currentMillis < 2000)//test interval
    if (brightness_SEL == 0)
    //if(vbattread <= 512 && brightness_SEL==0 && analogRead(Vusb_out) <= 899){}
      sleepMCU();
      bitClear(SMCR, SE);
      Serial.println("Wake up from LED off.");
      brightness_SEL = 1;  //testing
      goto L1;  //my way; trying to get rid of goto statement
  //code to turn of all LED activities
  sleepMCU();
  bitClear(SMCR, SE);
  Serial.println("Wake up from 2-sec delay.");
void sleepMCU()
  bitSet(SMCR, SE); //sleep enable bit must be HIGH before sleep_cpu() instruction\
  sleep_cpu();  //asm: sleep; the MCU sleeps
void wakeISR()
      sleepMCU();
      bitClear(SMCR, SE);
  sleepMCU();
  bitClear(SMCR, SE);
void sleepMCU()
void wakeISR()
Essentially the same as
return;
@kolaha and @jremington
Interesting! Give me sometimes to validate your proposed solutions.
Yes, but what about
I cant test it from under the umbrella, so in the meantime can someone say that this declaration works? If goto leads execution to L1, will currentMillis be updated, as it surely would be if the loop was execute again from the top?
It looks like an initialisation and I just don't know what happens in case it is run cross twice without having gone out of scope.
a7
Do you think this would be a problem (assuming that the compiler doesn't remove the call)?
I'm guessing it would be an error. No, I'm not guessing, I'm assuming it would be the same error as @Delta_G's.
But I don't see that it helps answer the question, is the variable re-initialised or not?
Still not where I could just run a test.
a7
So, according to this example (the second goto), a jump to a point before the lifetime of an object starts destroys the object in question. It seems to me that this means the following is also permitted.
l1:
  int x {10};
  Serial.println(x++);  // Prints `10` over and over again.
  goto l1;
1. I have done the following experiment which has established that the solutions provided by @kolaha in post #2 and @jremington in post #3 are the valid replacement of goto L1 instruction.
2. In my experiment, the MCU will go into sleep after glowing L (built-in LED of UNO) for 10-sec; however, if Battery voltage (which I have simulated using a switch at DPin-4) goes LOW before the elapse of this 10-sec time, the MCU will also go into sleep.
3. This is the Flow Chart (Fig-1) of the process, which I have not optimized for the shake of clarity.
Figure-1:
4. This is the test sketch which I have also not optimized for the shake of clarity.
  pinMode(13, OUTPUT);  //LED at DPin-13
  pinMode(2, INPUT_PULLUP);  //MCU wake up trigger
  pinMode(4, INPUT_PULLUP);  //Battery status at DPin-4
  digitalWrite(13, HIGH);  //LED is ON
  attachInterrupt(digitalPinToInterrupt(2), wakeUpIsr, LOW);
  while (millis() - currentMillis < 10000) //test interval
    if (digitalRead(4) == LOW)
      digitalWrite(13, LOW);  //LED is Off
      sleepMCU();  //MCU sleeps
      Serial.println("WakeupBatt.");    //MCU is wake up
      bitClear(SMCR, SE);
      while (digitalRead(4) != HIGH) //checking if Battery volt ok
      digitalWrite(13, HIGH); //LED is On
      currentMillis = millis();//return;//goto L1; all three codes work
  Serial.println("Wakeup10sec.");   //MCU is wake up
  bitClear(SMCR, SE);
void sleepMCU()
  bitSet(SMCR, SE);
  sleep_cpu();
void wakeUpIsr()
5. Serial Monitor Output:
Wakeup10sec.
Wakeup10sec.
WakeupBatt.
Wakeup10sec.
WakeupBatt.
6. Thanks to you all for helping me to convert my ignorance into knowledge.
7. Question:
The return statement is used at the end of a sub-routine for reverting to the main line program (the calling program). In my sketch, there is no sub-routine that has been called upon -- then how does return bring the control at the beginning of the loop() function?
8. Observation:
I have some reservations with the solution of @kolaha in post#2; where, the same instruction (currentMillis = millis()) is being executed twice to arrive at the beginning of the loop() function. If I delete this instruction: currentMillis = millis(), then the timing is not 10-sec (the test interval); rather it is erratic.
Of course there is. The hidden function main() calls loop() repeatedly, which is why "return" works.
So what is wrong with using a GOTO?
Same as falling into a black hole - spaghetti-fication
That means that the return statement brings the control next to the exit point of the main() function. After that main() function calls upon the loop() function and program execution begins at label L1 (sketch of post #14). Also, at the end of loop() function the control goes back to the main() function.
If the above is the case, then the solution of post #2 @kolaha needs more clarification as to how his solution brings the control at label L1.
Arduino main function code
#include <Arduino.h>
int main(void)
    init();
#if defined(USBCON)
    USBDevice.attach();
#endif
    setup();
    for (;;) {
        loop();
        if (serialEventRun) serialEventRun();
    return 0;
is not.
ends and
will continue, but after
loop() starts over and
is executed.
They do the same job; but, return is more expensive than goto as the former goes back to main() function and the later remains within the loop() function.
Yes! Now, I understand.
If brightness_SEL = 0, the MCU goes to sleep and after waking up, the process checks if the "argument of while() loop" is satisfied; otherwise, it will continue for the rest of the time (Section-8 of post #14) which is certainly less than 2-sec (10-sec in post #14).
I have observed this phenomenon in my experiment of post #14, which you have conceived institutively (without doing any experiment) long ago and accordingly you have inserted this code: currentMilllis = millis() to revert control at the beginning of while-do loop (and NOT at label L1) with fresh 2-sec (it is 10-sec in post #14) check-time.
Now, I have better understanding how the while-do loop works in a multi-tasking environment.
Now, I have got two correct answers (from post #2 and post #3) which cannot be simultaneously marked as Solution(s).
I would prefer to mark post #3 as Solution (in spite of its more cost than post #2) as it does exactly what OP (I) has wanted (going to label L1). (OP has desired to revert at label L1 owing to less clear vision on how while-do works!)
I would like to leave post #3 (and of course post #2 and others) for class room studies with my under graduate pupils.
Once again, thank you all for sharing the wisdoms.
It depends which you value more - machine cycles or hair follicles.
In the case of PC, while running C Program, the return 0; takes the control to the Operating System (DOS/WIN10). In the case of Arduino, what is that OS? I mean which program calls the main() function.
Where can I find the expansion of init() function to see the initialization tasks being carried out?
