if ((millis() - lastStateChangeTime) > dialHasFinishedRotatingAfterMs) {
// the dial isn't being dialed, or has just finished being dialed.
if (needToPrint) {
// if it's only just finished being dialed, we need to send the number down the serial
// line and reset the count. We mod the count by 10 because '0' will send 10 pulses.
Serial.print(count % 10, DEC);
needToPrint = 0;
count = 0;
cleared = 0;
if (reading != lastState) {
lastStateChangeTime = millis();
if ((millis() - lastStateChangeTime) > debounceDelay) {
// debounce - this happens once it's stablized
if (reading != trueState) {
// this means that the switch has either just gone from closed->open or vice versa.
trueState = reading;
if (trueState == HIGH) {
// increment the count of pulses if it's gone high.
count++;
needToPrint = 1; // we'll need to print this number (once the dial has finished rotating)
lastState = reading;
I guess it should be wired like this if the dial contact is normally closed. You could alternatively use an internal pull up resistor instead of the external 10K resistor if the assumptions here are correct.
You should have auto-formatted and posted your code like this:
int needToPrint = 0;
int count;
int in = 2;
int lastState = LOW;
int trueState = LOW;
long lastStateChangeTime = 0;
int cleared = 0;
// constants
int dialHasFinishedRotatingAfterMs = 100;
int debounceDelay = 10;
pinMode(in, INPUT);
int reading = digitalRead(in);
if (needToPrint) {
needToPrint = 0;
count = 0;
cleared = 0;
count++;
