//ADC - one chanel takes (approximately) 1us [1 microsecond]
// Serial.begin(9600);
SerialUSB.begin(115200); //...change it from the programming port to the native USB port; then ... SerialUSB.print(yourData);
// change the resolution to 12 bits and read A0
analogReadResolution(12);
// change the PWM resolution to 12 bits
// the full 12 bit resolution is only supported
// on the Due
//analogWriteResolution(12); //for direct access to DAC not needed
// this is a cheat - enable the DAC
analogWrite(DAC0,0);
analogWrite(DAC1,0);
int t=analogRead(0);
ADC->ADC_MR |= 0x80; // these lines set free running mode on adc 7 and adc 6 (pin A0 and A1 - see Due Pinout Diagram thread)
ADC->ADC_CR=2;
ADC->ADC_CHER=0xC0; // this is (1<<7) | (1<<6) for adc 7 and adc 6
int N=1000;
int t=micros();
int q0=0,q1=0;
int a0,a1,u0=0,u1=0;
for(int i=0;i<N;i++){
while((ADC->ADC_ISR & 0xC0)!=0xC0);// wait for two conversions (pin A0[7] and A1[6])
a0=ADC->ADC_CDR[7]; // read data on A0 pin
a1=ADC->ADC_CDR[6]; // read data on A1 pin
q0+=a0;
q1+=a1;
analogWrite(DAC0, 4095); //output voltage at value set to 0: 0.544V, 2048: 1.650V, 4095: 2.75V
analogWrite(DAC1, 2048); //function analogWrite takes "longer (cca. 2-3 us / chanel)
u0++;
if(u0 > 4095) u0 = 0;
u1++;
if(u1 > 4095) u1 = 0;
/* write to DAC0 */
//direct access to registers of DAC, value is "always" 12bits, fastest way(?, hope so) (http://rcarduino.blogspot.sk/2012/12/arduino-due-dds-part-1-sinewaves-and.html)
dacc_set_channel_selection(DACC_INTERFACE, 0);
dacc_write_conversion_data(DACC_INTERFACE, 2047);
/* write to DAC1 */
dacc_set_channel_selection(DACC_INTERFACE, 1);
dacc_write_conversion_data(DACC_INTERFACE, 1024);
t=micros()-t;
Serial.print("1000 pairs of ADC and DAC conversions in ");Serial.print(t);Serial.println(" micros");
Serial.print("A0 total:");Serial.println(q0);
Serial.print("A1 total:");Serial.println(q1);
SerialUSB.print(t); SerialUSB.println(" micros");
