How to improve Arduino Portenta H7 ADC Sampling Rate
I am trying to test the ADC sampling rate of Arduino Portenta H7. Using this basic code I can get 250 KSample / sec
// ARDUINO H7 ADC TEST
// test adc reading sampling rate on a floating pin
/* DEFINE */
// how many samples to combine
#define SAMPLES (1000)
/* INIT */
int analogPin = A0;
long val = 0;
long dataSum = 0;
long dataAvg = 0;
long timeStart = 0;
long timeElapsed = 0;
int nn = 0;
/* SETUP */
void setup(){
  // set analog read resolution
  analogReadResolution(12);
  Serial.println(" Test Arduino Portenta H7 ADC samplig rate ");
/* LOOP */
void loop(){
  // record time start
  timeStart = millis();
  // averaging samples
  for (int i = 0; i < SAMPLES; i++){
    val = analogRead(analogPin);
    dataSum += val;
    nn++;
  // time elapsed in msec
  timeElapsed = millis() - timeStart;
  // data average
  dataAvg = dataSum / nn;
  // print sampling rate
  Serial.print(" # KSamples/sec: ");
  Serial.print(nn/timeElapsed);
  // print time elapsed
  Serial.print(" Time elapsed msec: ");
  Serial.print(timeElapsed);
  // print adc data average
  Serial.print( " ADC data average: ");
  Serial.println(dataAvg);
  // reset counter
  nn = 0;
  dataSum = 0;
  delay(2000);
But Arduino Portenta ADC tech specs shows:
ADC: 3× ADCs with 16-bit max. resolution up to 36 channels, up to 3.6 MSPS
which is defintely higher than the one I have obtained
How can I improve the ADC sampling rate ?
Hello macromauro,
Maybe taking a look at this PDF could help:
https://www.st.com/resource/en/application_note/dm00628458-getting-started-with-the-stm32h7-series-mcu-16bit-adc-stmicroelectronics.pdf
and this one too:
https://www.st.com/resource/en/application_note/cd00211314-how-to-get-the-best-adc-accuracy-in-stm32-microcontrollers-stmicroelectronics.pdf
HTH,
John W.
Hello jwestmoreland,
many many thanks for sharing these resources, it helps !!!
because I am very new to STM32 world, can you please suggest a basic resources to start to play with ADC and DMA ?
Is there any way to improve my simple code using arduino programming language ?
many thanks
