Portenta H7: use DAC and ADC simultaneously
I am using a Portenta H7 on a breakout board, because I need the 12bit DAC and the 16bit ADC.
I can use the AdvancedAnalog library to read out my A0 pin (ADC) or creat a sinus on the A6 pin (DAC).
However, I fail whenever I try to read out A0 and use A6 at the same time. Even when they are not running at the same time but with 1s in between, the readout of A0 is not stable (see image, readout should be 1.55V continuously).
The image was produced with this code:
#include <Arduino_AdvancedAnalog.h>
#define DAC_PIN A6
#define ADC_PIN A0
#define SAMPLE_RATE       10000        // Hz
#define DURATION_MS       2000         // pro Phase
#define SAMPLES_PER_WAVE  45
#define AMPLITUDE         100
#define DAC_OFFSET        2000
AdvancedDAC myDac(DAC_PIN);
AdvancedADC myAdc(ADC_PIN);
uint16_t wave[SAMPLES_PER_WAVE];
int waveIndex = 0;
void generateWave() {
  for (int i = 0; i < SAMPLES_PER_WAVE; i++) {
    float angle = 2.0 * PI * i / SAMPLES_PER_WAVE;
    wave[i] = sin(angle) * AMPLITUDE + DAC_OFFSET;
  generateWave();
  // DAC starten
  if (!myDac.begin(AN_RESOLUTION_12, SAMPLE_RATE, SAMPLES_PER_WAVE, 32)) {
    Serial.println("DAC Init fehlgeschlagen");
    while (true);
  // ADC vorbereiten
  if (!myAdc.begin(AN_RESOLUTION_16, SAMPLE_RATE, SAMPLES_PER_WAVE, 64)) {
    Serial.println("ADC Init fehlgeschlagen");
    while (true);
  Serial.println("Bereit. Sende 'S' zum Start.");
  if (Serial.available()) {
    String cmd = Serial.readStringUntil('\n');
    cmd.trim();
    if (cmd == "S") {
      Serial.println("▶️ Phase 1: DAC-Ausgabe für 2 s");
      uint32_t dacStart = millis();
      while (millis() - dacStart < DURATION_MS) {
        if (myDac.available()) {
          SampleBuffer buf = myDac.dequeue();
          for (size_t i = 0; i < buf.size(); i++) {
            buf[i] = wave[waveIndex];
            waveIndex = (waveIndex + 1) % SAMPLES_PER_WAVE;
          myDac.write(buf);
      Serial.println("⏸ DAC-Ausgabe beendet");
      Serial.println("▶️ Phase 2: ADC-Messung für 2 s");
      uint32_t adcStart = millis();
      Serial.println("ADC_START");
      while (millis() - adcStart < DURATION_MS) {
        if (myAdc.available()) {
          SampleBuffer buf = myAdc.read();
            uint16_t val = buf[i];
            Serial.write((uint8_t*)&val, 2);  // 2 Bytes pro Sample
          buf.release();
      Serial.println("ADC_END");
      Serial.println("✅ Messung abgeschlossen");
I tried separating the two tasks but so far I have not found a solution. Is there no Timer/Ticker or something that works on the Portenta (other than the one from mbed.h)? Millis does not do the job, analog.write and analoge.read do not work simultaneously. Even separating both loops onto the M7 and the M4 core did not work and only produced more problems. I am out of ideas and could use some help. Thanks
No repleis yet. Try and use this link: " How to get the best out of this forum - Development Tools / IDE 1.x - Arduino Forum"
See if this helps: Missing buf.release() Add after myDac.write(buf);
I do not have the parts and can only take a SWAG (Scientific Will Assumed Guess).
buf.release() is a good thing to do, thank you. However, it does not help in using DAC and ADC simultaneously
Sorry that is all I can offer, hopefully others can help you.
