How to initialize DFPlayer mini with Arduino Nano ESP32
I've tried many fixes with my setup, but can't make it work somehow.
I'm trying to initialize a DFPlayer mini with an Arduino Nano ESP32, but have had no success so far.
See below for the wiring and the code, I'd appreciate any hints!
#include "Arduino.h"
#include "DFRobotDFPlayerMini.h"
HardwareSerial mySerial(1);
const int RX_PIN = 6;
const int TX_PIN = 7;
DFRobotDFPlayerMini myDFPlayer;
  mySerial.begin(9600, SERIAL_8N1, RX_PIN, TX_PIN);
  if (!myDFPlayer.begin(mySerial, true, true)) {
    Serial.println(F("Error: Couldn't initialize.));
    while (true);
  Serial.println(F("DFPlayer Mini initialized!"));
  myDFPlayer.volume(20);
  Serial.println(F("Volume set to 20"));
  Serial.println(F("Playing Track 1..."));
  myDFPlayer.play(1);
  // If I ever get here lol
The 1K resistor is not necessary. The Nano ESP32 and the DFPlayer mini are both 3.3V devices. But the 1K should not stop it from working.
The ESP tx should go to the DF rx - and the ESP rx should go to the DF tx.
place a
delay(2000);
in the line after the mySerial.begin
Wouldn't it be better to put
while (!mySerial);
in place of the delay()?
ok
either way
So I'd do:
const int RX_PIN = 0;
const int TX_PIN = 1;
then?
No, because the player is connected to pins 6, 7
What's "6" assigned to? Where's it going?
What's "7" assigned to? Where's it going?
I thought your answer above suggested moving the connected ESP PINs from 6/7 to the labeled TX/RX-PINs (D0/D1).
D6 is connected to DFPlayer RX, D7 is connected to DFPlayer TX.
And you have defined D6 to be an Rx pin, and D7 to be a Tx pin.
So you have two receivers connected, and two transmitters connected.
That is a problem.
A transmitting pin must be connected to a receiving pin. And vice versa.
I see, I switched them around since a lot of posts suggested that, whoops.
After switching them one last time, it actually works! I could swear I tried this, but apparently not. I incorporated @runaway_pancake 's suggestion too, adding a delay after the serial.begin().
Thanks everyone for helping me out!
Last time I ever answer a "DFPlayer" 'question' again.
