How to isolat cf ,cf1 and sel from esp in hlw8012 ic?
Hi everyone,
I am designing an energy monitoring circuit using the HLW8012 metering IC interfaced with an ESP microcontroller (ESP32 / ESP8266).
Because the HLW8012 has its reference ground directly tied to mains neutral/line, I want to fully isolate the low-voltage MCU side from the high-voltage mains side for safety.
I need advice on how to properly connect optocouplers (or digital isolators) for the three digital lines:
  • CF (Output from HLW8012): Active power pulse output.
  • CF1 (Output from HLW8012): Voltage/Current RMS pulse output.
  • SEL (Input to HLW8012): MCU signal to toggle current/voltage reading mode.
Specifically:
  1. Which optocouplers or high-speed isolators (e.g., PC817 vs. 6N137) work best given the pulse frequencies of CF/CF1?
  2. How should the pull-up resistors and emitter/collector configurations be wired across both isolated power domains?
Thanks in advance for any schematics, component recommendations, or guidance!
Why?
I have a similar power meter with the ESP inside an enclosure, directly connected to mains.
The isolation is the wireless link.
Arte you re-inventing a US$10 smart plug?
https://www.digikey.com/en/products/detail/texas-instruments/ISOM8710DFFR/21298742
@praneshmechatronics
Still need help?
