How to layout a custom PCB with an ESP32S3 and integrated antenna?
I am interested in the group's recommendations and experiences with PCB layout using ESP32S3 boards with integrated antennas.
I am using an ESP32S3 DevKitC-1 in a socket on my PCB for prototyping and then will convert to a smaller version later. I have a 4 layer PCB - L1=signals, L2=ground, L3=power, and L4=signals.
I can envision 3 options for the antenna:
  1. Have the integrated antenna hang over the edge of the PCB - recommended design from Espressif. Seems like a great opportunity to break or damage the antenna when handling the board, inserting the board into an enclosure, etc.
  2. Create a copper exclusion zone under the antenna at least 15 mm from the edges of the antenna. Doable, but takes up a lot of board space, especially when the ESP32 is in the middle of the board.
  3. Have the edge of the antenna just inside the edge of the PCB, and create a copper exclusion zone from the edge of the ESP32 to the edge of the board. Basically, the top ~6 mm of the PCB is a copper exclusion zone.
What do you do in this situation?
did you read the official documentation and recommendations on the Espressiif’s site?
Have you ruled out using a module with an Ipex antenna of the sort that is delivered with, for example, the xiao esp32 s3 ?
Or your option 3 but actually cut the board away under the antenna instead of simply not putting any copper under it. Google for "cheap yellow display" and you see an example of this.
I do option 3, I use an ESP32S (not an S3) but that shouldn't matter. WiFi works fine no issues. I have the ESP32 mounted towards a corner to minimize space loss, though it does complicate the pin connections a little bit. (should be less for a 4 layer PCB than my 2 layer one) Keep in mind that ideally the rest of the ESP32 (everything but the antenna section) should be shielded using a GND plane (pin connection traces cab pass if needed) and should also act as a heatsink.
For optimal RF performance do Number 1
You won't break the antenna.
For this design I cannot use the lpex antenna. Cutting the board away is an interesting 4th option!
As I said in my original post, Espressif recommends hanging the antenna off the edge of the board. The implication of that statement is that I read that information in the Espressif documentation.
