How to make a servo sweep once back and forth with the same keyboard key.
I’m trying to make a servo sweep once when I press a keyboard key, say ‘d’, and then sweep back when I press ‘d’ again.
This is the code I’ve tried to write:
#include<Servo.h> // include server library
Servo ser; // create servo object to control a servo
int poser = 0; // initial position of server
int val; // initial value of input
  Serial.begin(9600); // Serial comm begin at 9600bps
  ser.attach(9);// server is connected at pin 9
  if (Serial.available()) // if serial value is available
    val = Serial.read();// then read the serial value
    if (val == 'd' && poser == 0) //if value input is equals to d and the position is 0
      poser += 180; //than position of servo motor increases by 180 ( anti clockwise)
      ser.write(poser);// the servo will move according to position
      delay(15);//delay for the servo to get to the position
    if (val == 'd' && poser > 0) //if value input is equals to d and the position is greater than 0
      poser -= 180; //than position of servo motor decreases by 180 (clockwise)
This only moves the servo once and then nothing else when I press ‘d’.
This code is my attempt at modifying this code:
    if (val == 'd') //if value input is equals to d
      delay(10);//delay for the servo to get to the position
    if (val == 'a') //if value input is equals to a
This code works when I press ‘d’ for one direction and ‘a’ for the other direction. I just want to be able to do this with one key though.
Thanks for the help.
In your first program change this
to this
else if (val == 'd' && poser > 0)
so that it only applies one of the options at any one time
…R
Robin2:
to this
...R
That worked perfectly, Thank you!! :slight_smile:
