Material preparation
LinkNode D1 x 1
Arduino IDE
Step
Login linksprite.io ,and record the “Device ID” and “API key”
Register www.linksprite.io and Login this account
My Profile -> API key
My device->Create DIY Device
Enter Device Name,Device Type , Group Name , the device number is 00, device name and device grouping can be any.
Note: Device Type must be selected 00(Custom device type) .
Now you can see “test” in My Devices, Click “test” and record the Device ID.
Download and run the code
Download the source files
1 git clone GitHub - delongqilinksprite/LinkSpriteIO: This is demo about how to use LinkNode D1 and LinkNode R4 connect to linksprite.io
2. Put the code in the following directory(examples under Arduino installation directory )
- Open the Arduino IDE, File -> Example -> LinkSpriteIO-> LinkSpriteIO.ino
- Modify the “deviceID” and “apikey” with your own
Configure LinkNode D1 Engineering Environment
compile and run the code
Results
Open the serial port and www.linksprite.io to observe phenomena.
serial port
Here we can see communication of LinkNode D1 and linksprite.io.
Note:
The first use of LinkNode D1 need to connect the WiFi, the specific operation, please refer to the linksprite wiki Tutorial 4 .
