When using the internal 1.1V reference voltage, I powered an ESP32 with 5V USB and measured a 1.5V source using one of the ADC inputs, this got me 4095 as the ADC measurement which was expected as 1.5>1.1. However, when powering the ESP32 with a 3.3V battery directly with the 3.3V port, I got an ADC value of ~1600 which is completely wrong.
I have tried with 2 boards, the MakerHawk ESP32 (https://www.amazon.co.uk/gp/product/B076P8GRWV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1) and the MELIFE ESP32-DevKitC (https://www.amazon.co.uk/gp/product/B0811LGWY2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1)
This is the code I used and the ADC port was GPIO36.
#include "esp_adc_cal.h"
Serial2.begin(9600, SERIAL_8N1, 2, 17); //2 = RX, 17 = TX
adc1_config_width(ADC_WIDTH_12Bit);
adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_0db); //set reference voltage to internal
//Obtain ADC reading
int adcValue = adc1_get_raw(ADC1_CHANNEL_0);
//Send reading over UART to another ESP32 which is connected to laptop so can view ADC reading on serial monitor
Serial2.write(adcValue); //Bits 7:0 of integer 'adcValue'
Serial2.write(adcValue>>8); //Bits 15:8 of integer 'adcValue'
This is the header file used:
// Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
#ifndef __ESP_ADC_CAL_H__
#define __ESP_ADC_CAL_H__
#include <stdint.h>
#include "esp_err.h"
#include "driver/adc.h"
#ifdef __cplusplus
extern "C" {
#endif
* @brief Type of calibration value used in characterization
typedef enum {
ESP_ADC_CAL_VAL_EFUSE_VREF = 0, /**< Characterization based on reference voltage stored in eFuse*/
ESP_ADC_CAL_VAL_EFUSE_TP = 1, /**< Characterization based on Two Point values stored in eFuse*/
ESP_ADC_CAL_VAL_DEFAULT_VREF = 2, /**< Characterization based on default reference voltage*/
ESP_ADC_CAL_VAL_MAX,
ESP_ADC_CAL_VAL_NOT_SUPPORTED = ESP_ADC_CAL_VAL_MAX,
} esp_adc_cal_value_t;
* @brief Structure storing characteristics of an ADC
* @note Call esp_adc_cal_characterize() to initialize the structure
typedef struct {
adc_unit_t adc_num; /**< ADC number*/
adc_atten_t atten; /**< ADC attenuation*/
adc_bits_width_t bit_width; /**< ADC bit width */
uint32_t coeff_a; /**< Gradient of ADC-Voltage curve*/
uint32_t coeff_b; /**< Offset of ADC-Voltage curve*/
uint32_t vref; /**< Vref used by lookup table*/
const uint32_t *low_curve; /**< Pointer to low Vref curve of lookup table (NULL if unused)*/
const uint32_t *high_curve; /**< Pointer to high Vref curve of lookup table (NULL if unused)*/
} esp_adc_cal_characteristics_t;
* @brief Checks if ADC calibration values are burned into eFuse
* This function checks if ADC reference voltage or Two Point values have been
* burned to the eFuse of the current ESP32
* @param value_type Type of calibration value (ESP_ADC_CAL_VAL_EFUSE_VREF or ESP_ADC_CAL_VAL_EFUSE_TP)
* @note in ESP32S2, only ESP_ADC_CAL_VAL_EFUSE_TP is supported. Some old ESP32S2s do not support this, either.
* In which case you have to calibrate it manually, possibly by performing your own two-point calibration on the chip.
* @return
* - ESP_OK: The calibration mode is supported in eFuse
* - ESP_ERR_NOT_SUPPORTED: Error, eFuse values are not burned
* - ESP_ERR_INVALID_ARG: Error, invalid argument (ESP_ADC_CAL_VAL_DEFAULT_VREF)
esp_err_t esp_adc_cal_check_efuse(esp_adc_cal_value_t value_type);
* @brief Characterize an ADC at a particular attenuation
* This function will characterize the ADC at a particular attenuation and generate
* the ADC-Voltage curve in the form of [y = coeff_a * x + coeff_b].
* Characterization can be based on Two Point values, eFuse Vref, or default Vref
* and the calibration values will be prioritized in that order.
* @note
* For ESP32, Two Point values and eFuse Vref calibration can be enabled/disabled using menuconfig.
* For ESP32s2, only Two Point values calibration and only ADC_WIDTH_BIT_13 is supported. The parameter default_vref is unused.
* @param[in] adc_num ADC to characterize (ADC_UNIT_1 or ADC_UNIT_2)
* @param[in] atten Attenuation to characterize
* @param[in] bit_width Bit width configuration of ADC
* @param[in] default_vref Default ADC reference voltage in mV (Only in ESP32, used if eFuse values is not available)
* @param[out] chars Pointer to empty structure used to store ADC characteristics
* @return
* - ESP_ADC_CAL_VAL_EFUSE_VREF: eFuse Vref used for characterization
* - ESP_ADC_CAL_VAL_EFUSE_TP: Two Point value used for characterization (only in Linear Mode)
* - ESP_ADC_CAL_VAL_DEFAULT_VREF: Default Vref used for characterization
esp_adc_cal_value_t esp_adc_cal_characterize(adc_unit_t adc_num,
adc_atten_t atten,
adc_bits_width_t bit_width,
uint32_t default_vref,
esp_adc_cal_characteristics_t *chars);
* @brief Convert an ADC reading to voltage in mV
* This function converts an ADC reading to a voltage in mV based on the ADC's
* characteristics.
* @note Characteristics structure must be initialized before this function
* is called (call esp_adc_cal_characterize())
* @param[in] adc_reading ADC reading
* @param[in] chars Pointer to initialized structure containing ADC characteristics
* @return Voltage in mV
uint32_t esp_adc_cal_raw_to_voltage(uint32_t adc_reading, const esp_adc_cal_characteristics_t *chars);
* @brief Reads an ADC and converts the reading to a voltage in mV
* This function reads an ADC then converts the raw reading to a voltage in mV
* based on the characteristics provided. The ADC that is read is also
* determined by the characteristics.
* @note The Characteristics structure must be initialized before this
* function is called (call esp_adc_cal_characterize())
* @param[in] channel ADC Channel to read
* @param[in] chars Pointer to initialized ADC characteristics structure
* @param[out] voltage Pointer to store converted voltage
* @return
* - ESP_OK: ADC read and converted to mV
* - ESP_ERR_TIMEOUT: Error, timed out attempting to read ADC
* - ESP_ERR_INVALID_ARG: Error due to invalid arguments
esp_err_t esp_adc_cal_get_voltage(adc_channel_t channel, const esp_adc_cal_characteristics_t *chars, uint32_t *voltage);
#ifdef __cplusplus
#endif
#endif /* __ESP_ADC_CAL_H__ */
