How to modify the code for stepper motor control , make it simpler.
I have following code, which move stepper motor to 4 positions, how to modify the code for stepper motor control , make it simpler. i.e. only let code run based on the motor data table:
(use Array??)
Steps Dir Delay(After that position)
Position1 125 HIGH 1000
Position2 225 LOW 1800
Position3 325 HIGH 1200
Position4 208 HIGH 900
Thank!
Current Code:
int pushbuttonpin =7;            //Pin for momentary push button switch or sensor
int val = 0;                    //Integer for reading push button switch status
int dirpin = 3;                 //pin for DIR
int steppin = 2;                //pin for STEP
   pinMode(pushbuttonpin, INPUT);     //Declare push button switch pin as input
   pinMode(dirpin, OUTPUT);           //Declare dirpin as output
   pinMode(steppin, OUTPUT);          //Declare steppin as output
  int i;
  val = digitalRead(pushbuttonpin);   //Read push button switch pin status
  if (val == HIGH)
     digitalWrite(dirpin, HIGH);   // Set the direction pin to move forward
     delay(500);                     //Give it some time
      for (i = 0; i<125; i++)         // Step Forward 125 steps
          digitalWrite(steppin, LOW);      // Start out with step pin low
          delayMicroseconds(3000);          // Delay controls speed and Torque.
          digitalWrite(steppin, HIGH);     // Now switch it high
          delayMicroseconds(3000);          // Delay controls speed and Torque you need at least a 680 delay
   delay(1000); //stop at 1st. position for a while
     digitalWrite(dirpin, LOW);
      for (i = 0; i<225; i++)         // Step Backward to position #2
   delay(1800); //stop at 2nd. position for a while
      for (i = 0; i<325; i++)         // Step Forward to position #3
   delay(1200); //stop at 3rd. position for a while
      for (i = 0; i<208; i++)         // Step Forward to position #4
   delay(900); //stop at 4th. position for a while
Please edit your post and add code tags around the code part
type
** **[code]** **
before the code
type
** **[/code]** **
after the code
And read the how to use this forum" sticky.
Tables translate to either classes or structs; below example code using a struct.
Define a struct first that contains the information that you need; the below has one extra member for the delay while moving the stepper (not sure if it's useful).
struct POSITION
  int startposition;
  int endposition;
  unsigned long positiondelay;  // position delay in us
And next declare an array of positions
POSITION positions[] =
  {0, 33, 1000},
  {34, 66, 2000},
  {66, 99, 1000},
  {99, 255, 1000},
Next you can write a function for the moving
  move stepper
  IN:
    index in position array
void move(int index)
  for (int stepCnt = positions[index].startposition; stepCnt < positions[index].endposition; stepCnt++)
  delay(positions[index].positiondelay);
And you can call the function in loop()
  // which step
  static int step = 0;
  // move
  move(step++);
  // if all steps done, start from beginning
  if (step == sizeof(positions) / sizeof(positions[0]))
    step = 0;
You can add extra variables to the struct, e.g. the delay that you use in the for loop (according to your comment in the code it controls the torque).
sterretje:
That looks suspiciously like a blocking move!
How can the advocate of structs be recommending that ? :slight_smile:
...R
Simple :smiley: I know nothing about servos and how critical their timing is :slight_smile:
sterretje, your idea is very helpful, I changed my original code, many errors, Could you help me?
Thank you very much!
struct POSITION
  int steps;
  int dirs;
  {125,HIGH,1000},
  {225,LOW,1800},
  {325,HIGH,1200},
  {208,HIGH,900},
   int i;
   if (val == HIGH)
      digitalWrite(dirpin, dirs);   // Set the direction pin to move forward or backward
       for (i = 0; i<steps; i++)
    delay(positiondelay); //stop at the position for a while
    digitalWrite(dirpin, LOW);         //Change direction to reverse & back to home position
       for (i = 0; i<1300; i++)         // Step  to home position
You should post your errors. Anyway, you're missing two semicolons and 'dirs', 'positiondelay' and 'steps' are not variables that you can use directly (they are part of the struct).
Further the 'positions' variable is an array (of structs) so you need to indicate an array element first and next the variable inside that element; look at how I did it in the move() function.
You also do not seem to grasp the idea. Your loop() code still contains all steps while my suggested code only calls one function; I did overlook the direction in your original code though.
Hi sterretje, Thank u for your info.
Since stepper motor is open-loop, just need Steps & Dir, Why do you use startposition & endposition?
I assume a misunderstanding from my side.
Richard905:
If you use the Stepper library you can simplify your code to:
    stepper.step(125);
    stepper.step(-225);  // Negative number for reverse stepping
    delay(1800);
    stepper.step(325);
    delay(1200);
    stepper.step(208);
    delay(900);
johnwasser:
    stepper.step(125);
    delay(1800);
    stepper.step(325);
    delay(1200);
    stepper.step(208);
    delay(900);
johnwasser: The reason I want to use "Array" : Stepper Motor could move 100 and more positions, code will be very long!
Richard905:
If you are referring to this line of code from Reply #2
the start and end positions are just used to determine the number of steps
If you simply store the number of steps in your struct then that line could be
for (int stepCnt = 0; stepCnt < positions[index].numSteps; stepCnt++)
I mentioned in Reply #3 that using FOR causes the Arduino to be blocked until the FOR completes. The concept of using a struct could easily be used with the non-blocking movement in the second example in this Simple Stepper Code
...R
Stepper Motor Basics
Richard905:
Sorry. I thought you just wanted 'simpler'. You already have examples of using arrays. You can simplify those examples by using the Stepper library. You won't need to store 'Direction' since the sign of the number of steps selects direction. Each movement has just 'steps' and 'delay'.
Hi sterretje: I decided to give up my original code, the following code is based on yours, it passed & run.
{0, 1000, 1000},
{1000, 2000, 1000},
{2000, 1000, 1000},
{1000, 2000, 1000},
The 3rd step should be reverse? but didn't, run on direction only, loop will not end.
By the way, I need use one momentary switch to trigger the cycle, the stop until push the switch again.
I want add " val = digitalRead(pushbuttonpin); //Read push button switch pin status
if (val == HIGH)" , Where should I add in your code.(tried different places, no luck).
Thanks!
struct POSITION
  int startposition;
  int endposition;
  {0, 1000, 1000},
  {1000, 2000, 1000},
  {2000, 1000, 1000},
  {1000, 2000, 1000},
  move stepper
  IN:
  // which step
  // move
  move(step++);
    step = 0;
Richard905:
You have no code to test for that or to operate the direction pin
You need to do that before the FOR loop.
...R
[coce]
int pushbuttonpin = 7;           //Pin for momentary push button switch or sensor
struct POSITION
  unsigned steps;
  boolean direction;
  {125,      HIGH,              1000},
  {225,      LOW,               1800},
  {325,      HIGH,               1200},
  {208,      HIGH,               900}
  move stepper
  IN:
void move(struct POSITION &position) {
  digitalWrite(dirpin, position.direction);
  for (unsigned step = 0; step < position.steps; step++) {
  delay(position.positiondelay);
  // which step
  static unsigned step = 0;
  // move
  move(positions[step++]);
  if (step == sizeof(positions) / sizeof(positions[0])) {
    step = 0;
Added pushbutton.
struct POSITION {
  unsigned steps;
  boolean direction;
POSITION positions[] = {
  {125,      HIGH,              1000},
  {225,      LOW,               1800},
  {325,      HIGH,               1200},
  {208,      HIGH,               900}
  // Calculate the number of steps in the array
  unsigned stepCount = sizeof positions / sizeof positions[0];
  if (digitalRead(pushbuttonpin)) {
    long totalSteps = 0;
    // Run a full cycle
    for (unsigned step = 0; step < stepCount; step++) {
      struct POSITION &position = positions[step];
      if (position.direction)
        totalSteps += position.steps;  // direction == HIGH, move in + direction
        totalSteps -= position.steps;  // direction == LOW, move in - direction
      for (unsigned i = 0; i < position.steps; i++) {
      } // end for(i)
    } // end for(step)
    // Cycle is done so Now move back to the initial position
    if (totalSteps != 0) {  // No need to move.  We're already there!
      if (totalSteps > 0) {
        digitalWrite(dirpin, LOW);  // More HIGH than LOW so go in LOW direction
        digitalWrite(dirpin, HIGH);  // More LOW than HIGH so go in HIGH direction
        totalSteps = -totalSteps;  // Make totalSteps positive.
      // Move to the initial position
      for (long i = 0; i < totalSteps; i++) {
      } // end for(i)
  }  // end if(button)
johnwasser:
Added pushbutton.
struct POSITION {
  unsigned steps;
  boolean direction;
  {125,      HIGH,              1000},
  {225,      LOW,              1800},
  {325,      HIGH,              1200},
  {208,      HIGH,              900}
// Run a full cycle
      } // end for(i)
    } // end for(step)
      } // end for(i)
  }  // end if(button)
johnwasser: above code works great! if I want to use same array control two stepper motor, of course, they don't run at the same time.
int dirpin = 3; //pin for DIR of Stepper Motor "A"
int steppin = 2; //pin for STEP of Stepper Motor "A"
int dirpin = 5; //pin for DIR of Stepper Motor "B"
int steppin = 4; //pin for STEP of Stepper Motor "B"
{125, HIGH, 1000}, // Stepper Motor "A" rotates
{225, LOW, 1800}, // Stepper Motor "B" rotates
{325, HIGH, 1200}, // Stepper Motor "B" rotates
{208, HIGH, 900} // Stepper Motor "A" rotates
How to modify the code? (don't need move to the initial position)
Thanks again!
I would start by adding an entry in the structure for which motor to turn.
