How to parse data to use in a conditional statement
I'm using a ESP32 to as a proximity sensor to safeguard several android devices that are running an ibeacon simulator that's always on that the ESP32 is capable of detecting - which I've tested to make sure it works (see attached image).
Although, the mac addresses that the ibeacon simulator outputs constantly changes and therefore cannot be used, the manufactures id/data however from the ibeacon remains constant which can be used. As such when the code runs the following line...
Serial.printf("Advertised Device: %s \n", advertisedDevice.toString().c_str());
it outputs the entire ibeacon information which can be read in the attached image starting at the line reading "Advertised Device:..." letting me know that the code and the ESP32 are working properly to read and acquire the data of all the ibeacons in the area.
However, when I tell the code to execute a conditional function when the acquired manufacture data matches the manufacture data stored as a string in knownBLEAddresses... the condition does not function.
String knownBLEAddresses[] = {"4c000215b9a6adffaea94703903a58437a4d9d2400000000fd"};
As such, I then enabled the debugging within the code to see what the code is pulling as the just the manufacture data but for reasons unknown it only returns a single character or sometimes jibberish - which I've marked in red in the image. Which explains why the condition is not executing.
Serial.println(advertisedDevice.getManufacturerData().c_str());
So, unless someone can explain why the getManufacturerData() is not returning the correct information, I think the best work around to is parse the manufacture data (underlined in blue within the image) directly from
and use that to somehow match the manufacture data string stored within knownBLEAddresses and then use that to make this condition true somehow.
if (strcmp(advertisedDevice.getManufacturerData().toString().c_str(), knownBLEAddresses[i].c_str()) == 0)
          device_found = true;
However, I have no idea where to begin and could use some help.
Here is the entire code for reference.
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEScan.h>
#include <BLEAdvertisedDevice.h>
#define LED 2
int RSSI_THRESHOLD = -120;
bool device_found;
int scanTime = 5; //In seconds
BLEScan* pBLEScan;
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
    void onResult(BLEAdvertisedDevice advertisedDevice) {
      for (int i = 0; i < (sizeof(knownBLEAddresses) / sizeof(knownBLEAddresses[0])); i++)
        //Uncomment to Enable Debug Information
        Serial.println("*************Start**************");
        Serial.println(sizeof(knownBLEAddresses));
        Serial.println(sizeof(knownBLEAddresses[0]));
        Serial.println(sizeof(knownBLEAddresses)/sizeof(knownBLEAddresses[0]));
        Serial.println(knownBLEAddresses[i].c_str());
        Serial.println("*************End**************");
                          //break;
          device_found = false;
  Serial.begin(115200); //Enable UART on ESP32
  Serial.println("Scanning..."); // Print Scanning
  pinMode(LED, OUTPUT); //make BUILTIN_LED pin as output
  BLEDevice::init("");
  pBLEScan = BLEDevice::getScan(); //create new scan
  pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks()); //Init Callback Function
  pBLEScan->setActiveScan(true); //active scan uses more power, but get results faster
  pBLEScan->setInterval(100); // set Scan interval
  pBLEScan->setWindow(99);  // less or equal setInterval value
  BLEScanResults foundDevices = pBLEScan->start(scanTime, false);
  for (int i = 0; i < foundDevices.getCount(); i++)
    BLEAdvertisedDevice device = foundDevices.getDevice(i);
    int rssi = device.getRSSI();
    Serial.print("RSSI: ");
    Serial.println(rssi);
    if (rssi > RSSI_THRESHOLD && device_found == true)
      digitalWrite(LED, HIGH);
      digitalWrite(LED, LOW);
  pBLEScan->clearResults();   // delete results fromBLEScan buffer to release memory
Thank you
You do know that strcmp() returns 0 if the two strings are equal, don't you?
Are you sure your sketch compiles? When I select "ESP32 Dev Module" I get the following compile error:
sketch_jul22a.ino: In member function 'virtual void MyAdvertisedDeviceCallbacks::onResult(BLEAdvertisedDevice)':
sketch_jul22a:25:59: error: 'std::__cxx11::string' {aka 'class std::__cxx11::basic_string<char>'} has no member named 'toString'
exit status 1
A working alternative is:
std::string knownBLEAddresses[] =
         if (advertisedDevice.getManufacturerData() == knownBLEAddresses[i])
are you using 1.0.4 for theESP32 Dev Module? That's the version I'm using and yes I'm sure it compiles. And this ``std::string knownBLEAddresses[] =
     if (advertisedDevice.getManufacturerData() == knownBLEAddresses[i])``
won't work at the getManufacturerData() is returning nonsense, as its mentioned here in this article - https://github.com/nkolban/esp32-snippets/issues/565
Do you mean the ESP32 core version? I have 2.0.4 installed which appears to be the most current.
yes, I have to use 1.0.4 for this project
