I am trying to send an array counting from 0 to 219 from the Arduino Nano 33 BLE Sense to my PC. I am able to send the simple data (an array with 1 element only) and it works, I can successfully received the number on the other side, but there is an issue when I want to send a larger amount of data. On the PC side, I can receive this array (0->219) but when I want to decode it and get completely different values. Maybe you can suggest me where I make mistakes. Here is my code:
#include <ArduinoBLE.h>
const char* uuidOftxChar = "2d2F88c4-f244-5a80-21f1-ee0224e80658";
const char* uuidOfService = "180F";
const char* nameofPeripheral = "ImageSender";
const int RX_BUFFER_SIZE = 220;
bool RX_BUFFER_FIXED_LENGTH = false;
unsigned long prevNow = 0;
BLEService imageService(uuidOfService);
BLECharacteristic txChar(uuidOftxChar, BLEIndicate, RX_BUFFER_SIZE, RX_BUFFER_FIXED_LENGTH);
while (!Serial);
if (!BLE.begin()) {
Serial.println("starting BLE failed!");
while (1);
BLE.setLocalName(nameofPeripheral);
BLE.setAdvertisedService(imageService);
imageService.addCharacteristic(txChar);
BLE.addService(imageService);
BLE.setEventHandler(BLEConnected, blePeripheralConnectHandler);
BLE.setEventHandler(BLEDisconnected, blePeripheralDisconnectHandler);
BLE.advertise();
void blePeripheralConnectHandler(BLEDevice central) {
Serial.println("Connected event, central: ");
Serial.println(central.address());
void blePeripheralDisconnectHandler(BLEDevice central) {
Serial.println("Disconnected event, central: ");
BLE.poll();
long now = millis();
if (now - prevNow >= 5000) {
prevNow = now;
if (BLE.connected()) {
//int rssiValue = BLE.rssi();
//Serial.println(rssiValue);
Serial.println("Connected to central");
int numbers[221];
for(int k=0; k<221; k++){
numbers[k] = k;
Serial.println("First element in the array:");
Serial.println(numbers[0]);
Serial.println("Last element in the array:");
Serial.println(numbers[220]);
int counter = 0;
int i=0;
for(i; i<220; i+=RX_BUFFER_SIZE){
txChar.writeValue(numbers+i, 220);
counter+=1;
Serial.println(counter);
Serial.println(i);
Yes, as the array contains 220 numbers, and as I know in one BLE packet I can send max 256B (correct me if I am wrong), so here I will just pass immediately 220 bytes and send them. That is the reason why for loop will be executed only once and then again when I enter the loop, I will send the array again. This is how I imagined this test.
Now, the device will go through for loop 4 times until all data from numbers (array) are sent. When I do it like this, I am able to receive 880bytes but still not what I am expecting.
int i = 0;
int counter = 55;
// I have 220 integers (1 int-> 4B), which means that the size of my byte array will be 880bytes
while(i<880){
txChar.writeValue(numbers+counter, 220); // 220 bytes can cover 55 integers (55*4=220bytes)
counter+=55;
i+=220
Is there any specific method to check if data is successfully sent?
