anshls
November 25, 2021, 4:15pm
1
I have the ECG working right now from the amplifiers and the notch filter, and I have to program the arduino to get the signal and show it on the serial plotter, but it's so confusing. DO you guys have any examples I can use to do it? everything I have seen is by using the sensor, but I do not use that one.
Thanks in advance.
This is the signal I’m getting from the oscilloscope that I want to put on the Arduino serial plotter.
I’m actually just looking to get the BPM of the heart, but I want to see how to get it on my serial plotter.
Could you take a few moments to Learn How To Use The Forum
See also FAQ - Arduino Forum for general rules on forum behaviour and etiquette.
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is fru…
Your OS and version can be valuable information, please include it along with extra security you are using.
Always list the version of the IDE you are using and the board version if applicable.
Use quote or add error messages as an attachment NOT a picture.
How to insert an image into your post. ( Thanks @Robin2 )
Add your sketch where applicable but please use CODE TAGS ( </> )
Add a SCHEMATIC were needed even if it is hand drawn
Add working links to any specific hardware as needed (NOT links to similar items)
Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
Ensure you have FULLY inserted the USB cables.
Check you have a COMMON GROUND where required. ( Thanks @Perry )
Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
Try other computers where possible.
Try other USB leads where possible.
You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
There may be a problem with the board check or remove your wiring first.
Remove any items connected to pins 0 and 1.
COMPUTER RELATED
Close any other serial programs before opening the IDE.
Ensure you turn off any additional security / antivirus just to test.
There may be a problem with the PC try RESTARTING it.
You may be selecting the wrong COM port.
Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
Clear your browsers CACHE.
Close the IDE before using any other serial programs.
Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
CH340/341 based clones do not report useful information to the “get board info” button.
NANO (Old Types) some require you to use the OLD BOOTLOADER option.
NANO (ALL Types ) See the specific sections lower in the forum.
NANO (NEW Types ) Install your board CORE’s.
Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
On Linux ~/ArduinoCreateAgent-1.1/config.ini
On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
[/quote]
anshls
November 25, 2021, 5:35pm
3
I have read it and made the proper changes. I don't know what's wrong with my post but thanks for sending it agin.
What, precisely, is generating the waveform (and don't say a human heart...)
It's possible you could just connect the point you're scoping to the A0 analog input of an Uno and run something like:
const uint8_t pinECG = A0;
//don't need to declare A0 as input (default)
Serial.begin( 115200 );
}//setup
uint16_t ecg = analogRead( pinECG );
float volt = (float)ecg * 5.0 / 1024;
Serial.println( volt );
}//loop
anshls
November 26, 2021, 11:47am
5
I’m reading the frequency of the heart beat. I’ll try that and let you know.
Question: why 1156 and not 9600?
By "1156" are you referring to the serial baud rate? If so: Why not use 115200 or faster?
At 9600bps it takes a millisecond to send one byte over serial.
At 115200, that same byte takes ~87 microseconds. The less time spent doing something like waiting for serial bytes to be sent means more frequent sampling of your input signal.
system
Closed
May 25, 2022, 12:04pm
7
