So i have been working on a project using the Nano and stepper and servo motors which i think has naturally reached its limit. And would like to know how to develop my project further.
What im building can be thought of exactly like a 3d printer. And id like my project to run just as smoothly
The loop is just running too slowly now i have built my full circuit.
I have all digital inputs in use and a 74HC165 for 8 additional inputs that reads 8 push buttons.
I have two A4988 on nema 17s that i want to run at 1/16th step which i think is already far to many pulses for a arduino nano to cover while listening for buttons and controlling motors.
Then a 3rd SG90 servo for a small moving arm.
I have an LCD screen with I2C.
2 limit switches
I have no even tried sending it a plotting language design yet which i image will hugely tax the system converting it and running it.
So im wondering do i go on with arduino or should i start designing a custom microcontroller or find a off the shelf product i can still code.
I like the nano because they are easy to solder into circuit boards and then i can always update them and not waste the board. But could use a bigger one if that would work.
Can i just ramp up the baud rate to something high on a powerful board?
Maybe i can master slave some nanos and have one run the buttons and the other run the motors?
Sorry if this is not a great stack overflow question. Im just trying to get some ideas together to see how to evolve my project.
Thanks for any help.
Tom
I dont have a full code for it yet, i built all the components seperately and now am bringing them together, which is where i started to see the problem. So this is some basic test code im running but has my motors running poorly.
Code
include <Arduino.h>
#include <AccelStepper.h>
#include <Servo.h>
// Stepper motor connections
constexpr int dirPinMotorX = 2;
constexpr int stepPinMotorX = 3;
constexpr int dirPinMotorY = 4;
constexpr int stepPinMotorY = 5;
// Stepper motor configurations
AccelStepper stepperX(AccelStepper::DRIVER, stepPinMotorX, dirPinMotorX);
AccelStepper stepperY(AccelStepper::DRIVER, stepPinMotorY, dirPinMotorY);
// Define Connections to 74HC165
constexpr int shiftRegLoad = 8;
constexpr int shiftRegClockEnablePin = 7;
constexpr int shiftRegDataIn = 10;
constexpr int shiftRegClockIn = 9;
// Button binary codes on 74HC165
constexpr auto X_AXIS_BINARY = 0b11110111;
constexpr auto Y_AXIS_BINARY = 0b11111011;
constexpr auto START_X_MOTOR = 0b01111111;
constexpr auto START_Y_MOTOR = 0b10111111;
constexpr auto REVERSE_X_MOTOR = 0b11011111;
constexpr auto REVERSE_Y_MOTOR = 0b11101111;
// New button for manual mode
constexpr auto MANUAL_MODE = 0b11111110; // Example bitmask, set your actual value
constexpr int enablePinMotorX = 11; // Enable pin for X motor driver
// constexpr int enablePinMotorY = undefined; // Enable pin for Y motor driver
// Servo setup
Servo sg90Servo;
constexpr int servoPin = 12;
// Variable to store the previous state of the inputs
byte previousState = 0;
// Initialize stepper motors
stepperX.setMaxSpeed(500); // Reduced speed
stepperX.setAcceleration(200); // Reduced acceleration
stepperY.setMaxSpeed(500);
stepperY.setAcceleration(200);
// Initialize 74HC165 pins
pinMode(shiftRegLoad, OUTPUT);
pinMode(shiftRegClockEnablePin, OUTPUT);
pinMode(shiftRegClockIn, OUTPUT);
pinMode(shiftRegDataIn, INPUT);
// Initialize servo
sg90Servo.attach(servoPin);
// Read inputs from 74HC165
digitalWrite(shiftRegLoad, LOW);
delayMicroseconds(5);
digitalWrite(shiftRegLoad, HIGH);
digitalWrite(shiftRegClockIn, HIGH);
digitalWrite(shiftRegClockEnablePin, LOW);
byte incoming = shiftIn(shiftRegDataIn, shiftRegClockIn, LSBFIRST);
digitalWrite(shiftRegClockEnablePin, HIGH);
// Handle manual mode toggle
if (incoming == MANUAL_MODE) {
Serial.println("HIT");
static bool manualEnabled = false;
manualEnabled = !manualEnabled; // Toggle state
digitalWrite(enablePinMotorX, manualEnabled ? HIGH : LOW); // Disable or enable X motor
// digitalWrite(enablePinMotorY, manualEnabled ? HIGH : LOW); // Disable or enable Y motor
// Control logic for stepper motors based on input
if (incoming == X_AXIS_BINARY) {
stepperX.stop(); // Stop X Axis Motor
} else if (incoming == START_X_MOTOR) {
stepperX.move(400); // Move X motor 400 steps (adjust as needed)
} else if (incoming == REVERSE_X_MOTOR) {
stepperX.setSpeed(-stepperX.speed()); // Reverse X motor direction
if (incoming == Y_AXIS_BINARY) {
stepperY.stop(); // Stop Y Axis Motor
} else if (incoming == START_Y_MOTOR) {
stepperY.move(400); // Move Y motor 400 steps (adjust as needed)
} else if (incoming == REVERSE_Y_MOTOR) {
stepperY.setSpeed(-stepperY.speed()); // Reverse Y motor direction
// Execute stepper commands
stepperX.run(); // Respects both speed and acceleration
stepperY.run();
// Rotate the servo back and forth between 0 and 180 degrees
static bool direction = true;
static unsigned long lastMoveTime = 0;
