How to snchronize webcam recording and arduino using python?
Hello,
I am sending serial data from my arduino with python. The sending starts once I press a joysticksbutton. In my python script, this works very well, that serial data is only send when the button is pressed.
Now I want python to simultaneously start the laptop camera to record, once the button is pressed. However this does not work, unfortunately. The camera immediatly starts to record when I run the python script and does not wait for the "button signal" like the serial data does.
I dont know if this is the roght forum to ask a python question but I'd still appreciate any help!
#include <math.h>
const int Led_Green = 9;
const int Led_Yellow = 10;
const int Gate1 = 5;
const int Gate2 = 6;
const int Joystick_X = A0;
const int Joystick_Y = A1;
const int pushbutton = 3;
int JoystickValue_X = 0;
int JoystickValue_Y = 0;
const int middle_X = 512;
const int middle_Y = 512;
int pushbuttonState;
int JoystickValue_X_Y;
int tempsensor1 = A2;
int tempsensor2 = A3;
int tempsensor3 = A4;
int readVal1 = 0;
int readVal2 = 0;
int readVal3 = 0;
double Temp1 = 0;
double Temp2 = 0;
double Temp3 = 0;
int TempLimit;
double offset_degree;
double offset_degree1 = -2.2; // RT=26.0°C, difference
double offset_degree2 = 0.7;
double offset_degree3 = -2.47;
unsigned long deltaTime;
bool running = true;
//Define experiment (0 = manual, 1 = vollgas, 2 = , 3 = )
int experiment = 1;
//Define functions--------------------------------------------------------------------
void manual_function() {
      JoystickValue_X = analogRead (Joystick_X);                        // [0, 1023]
      JoystickValue_X = constrain(JoystickValue_X, middle_X, 1023);     // [512, 1023]
      JoystickValue_X = map(JoystickValue_X, middle_X, 1023, 0, 1023);   // [0, 100]
      JoystickValue_Y = analogRead (Joystick_Y);                        // [0, 1023]
      JoystickValue_Y = constrain(JoystickValue_Y, middle_Y, 1023);     // [512, 1023]
      JoystickValue_Y = map(JoystickValue_Y, middle_Y, 1023, 0, 1023);   // [0, 100]
        Serial.print(Temp1);
        Serial.print(";");
        Serial.print(Temp2);
        Serial.print(";");
        Serial.print(Temp3);
        Serial.print(";");
        Serial.print(JoystickValue_X);
        Serial.print(";");
        Serial.println(JoystickValue_Y);
//Funktion Temperatur offset und Umrechung-----------------------------------------------------
double Thermistor(int RawADC, int sensor_number)
    double Temp;
    Temp = log(10000.0 * ((1024.0 / RawADC - 1)));
    Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp )) * Temp );
    Temp = Temp - 273.15;            // Konvertierung von Kelvin in Celsius
    switch (sensor_number) {
  case 1:
    offset_degree = offset_degree1;
  case 2:
    offset_degree = offset_degree2;
   case 3:
    offset_degree = offset_degree3;
  default:
    offset_degree = 0;
    return Temp+offset_degree;
void case_function( int JoystickInput_X, int JoystickInput_Y, int TempLimit, int TempValue) {
    if(deltaTime < 45000L) {
    JoystickValue_X = JoystickInput_X;
    JoystickValue_Y = JoystickInput_Y;
        Serial.print(";");
        Serial.print(";");
        Serial.print(";");
        Serial.print(";");
    else if ((deltaTime >= 45000L) && (TempValue > TempLimit)) {
        Serial.print(";");
        Serial.print(";");
        Serial.print(";");
        Serial.print(";");
    else if ((deltaTime > 45000L) && (TempValue < TempLimit)) {
      Serial.print("Experiment done.");
      running = false;
  pinMode(Joystick_X, INPUT); // X-axis
  pinMode(Joystick_Y, INPUT); // Y-axis
  pinMode(pushbutton,INPUT); // press button
  digitalWrite(pushbutton, INPUT_PULLUP);
  pushbuttonState = digitalRead(pushbutton);
  while (digitalRead(pushbutton) == HIGH);
  if(running == true) {
    //currentTime = millis();
    //unsigned long deltaTime = CalculateDeltaTime();
    static unsigned long TimeZero = millis();
    deltaTime = millis() - TimeZero;
      Serial.print("start");
      Serial.print(";");
      Serial.print(deltaTime);
      Serial.print(";");
      readVal1 = analogRead(tempsensor1);
      Temp1 =  Thermistor(readVal1,1);
      readVal2 = analogRead(tempsensor2);
      Temp2 =  Thermistor(readVal2,2);
      readVal3 = analogRead(tempsensor3);
      Temp3 =  Thermistor(readVal3,3);
     switch(experiment) {
      case 0:
        manual_function();
       case 1:
         case_function(1023, 0, 18, Temp1);
       case 2:
         case_function(0, 1023, 23, Temp2);
       case 3:
         case_function(1023, 1023, 23, Temp3);
       case 4:
         case_function(1023, 0, 36, Temp1);
       case 5:
         case_function(0, 1023, 36, Temp2);
       case 6:
         case_function(1023, 1023, 36, Temp3);
         if (JoystickValue_Y <= 0) {
      analogWrite(Led_Green, 0);
      analogWrite(Gate1, 0);
    if (JoystickValue_Y > 0) {
      analogWrite(Led_Green, JoystickValue_Y/4);
      analogWrite(Gate1, JoystickValue_Y/4);
   if (JoystickValue_X <= 0) {
      analogWrite(Led_Yellow, 0);
      analogWrite(Gate2, 0);
   if (JoystickValue_X > 0) {
      analogWrite(Led_Yellow, JoystickValue_X/4);
      analogWrite(Gate2, JoystickValue_X/4);
my python scriot:
import serial
from datetime import datetime
import cv2
import csv
from RsInstrument import *
from time import sleep, localtime, strftime
import time
import gsv8
import usb.core
import pyvisa
import usb.util
# Serial Data from Arduino
ser = serial.Serial('COM6', 9600, timeout=1)
# Serial Data from Loadcell--------------------------------------------------------
#dev = gsv8.gsv8("COM9", 9600)  # load cell port
# Initialize and request instrument for all sessions via
RsInstrument.assert_minimum_version('1.22.0')
USB_adr_NGE = 'USB0::0x0AAD::0x0197::5601.3800k03-103085::0::INSTR'
nge = RsInstrument(USB_adr_NGE)
idn = nge.query_str('*IDN?')
while 'start' not in ser:
    while True:
        # Camera Start (Laptop)---------------------------------------------------------------------------------
        webcam = cv2.VideoCapture(0)
        frame_width = int(webcam.get(3))
        frame_height = int(webcam.get(4))
        size = (frame_width, frame_height)
        result_laptop = cv2.VideoWriter('NameAsDateTime_laptop.avi', cv2.VideoWriter_fourcc(*'MJPG'), 10, size)
        ret, frame = webcam.read()
        if ret == True:
           result_laptop.write(frame)
           cv2.imshow("Test", frame)
           key = cv2.waitKey(20) & 0xFF
           if key == ord("q"):
                webcam.release()
                break
        # Camera Start (external)-------------------------------------------------------------------------------
        camera = cv2.VideoCapture(2)
        frame_width2 = int(camera.get(3))
        frame_height2 = int(camera.get(4))
        size2 = (frame_width2, frame_height2)
        result_camera = cv2.VideoWriter('NameAsDateTime_camera.avi', cv2.VideoWriter_fourcc(*'MJPG'), 10, size2)
        ret_cam, frame_cam = camera.read()
        image = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
        if ret_cam == True:
            result_camera.write(frame_cam)
            cv2.imshow("Test cam", image)
            key_cam = cv2.waitKey(20) & 0xFF
            if key_cam == ord("w"):
                camera.release()
                break
        #get arduino data(temp)---------------------------------
        fileName = "temp_force_serialdata.csv"
        file = open(fileName, "a")
        getData = ser.readline()
        dataString = getData.decode('utf-8')
        data = dataString.rstrip()
        dateTimeObj = datetime.now()
        timestampStr = dateTimeObj.strftime("%d-%b-%Y (%H:%M:%S)")
        sensor_data = data.split(";")
        sensor_data.append(timestampStr)
        readings = data.split(";")
        sensor_data.append(readings)
        # get load cell data-------------------------------------
        measurement = dev.ReadValue()
        measurement_str = measurement.toString()
        measurement_arr = measurement_str.split(";")
        force_x = measurement_arr[1].split(":")[2]
        force_y = measurement_arr[2].split(":")[1]
        force_z = measurement_arr[3].split(":")[1]
        #get power supply data-----------------------------------
        V1 = 3.6
        C1 = 1000
        nge.write('INSTrument:NSELect 1')  # Choose CH1
        nge.write('OUTPut:STATe 1')  # Switch CH1 ON
        nge.write('SOURce:VOLTage:LEVel:IMMediate:AMPLitude ' + str(V1))  # Set voltage level
        nge.write('SOURce:CURRent:LEVel:IMMediate:AMPLitude ' + str(C1))  # Set current level
        voltage1 = nge.query_str('MEASure:SCALar:VOLTage:DC?')  # ...Voltage
        current1 = nge.query_str('MEASure:SCALar:CURRent:DC?')  # ...Current
        entry = timestampStr + ',' + ','.join(readings) + '\n'
        #entry = timestampStr + ',' + ','.join(readings) + ',' + force_x + ',' + force_y + ',' + force_z + '\n'
        #entry = timestampStr + ',' + ','.join(readings) + ',' + voltage1 + ', ' + current1 + '\n'
        print(entry)
        with open(fileName, 'a', encoding='UTF8') as f:
            f.write(entry)
        file.close()
        pass
Are you sure you want to indent the while True: after that ?
if I dont I get an indentation error
my point is you don't want to do
    while True:
while 'start' not in ser: (I assume you expect the Arduino to send 'start' when the button is pressed ?)
this is what triggers the camera right away.
Don't you want to wait and do nothing until you've received start?
yes thats exactly what I want to do, but I just dont know how
My experience is that I found best to use tasks in python to listen to the Serial port to collect commands (lines) asynchronously and deal with them
You could try to explore something like this (assuming your Arduino is on COM6)
Python:
#!/usr/bin/python3
import threading, queue, serial
arduinoQueue = queue.Queue()
def listenToArduino():
    message = b''
    while True:
        incoming = arduino.read()
        if (incoming == b'\n'):
            arduinoQueue.put(message.decode('utf-8').strip().upper())
            message = b''
        else:
            if ((incoming != b'') and (incoming != b'\r')):
                 message += incoming
def configureArduino():
    global arduino
    arduino = serial.Serial('COM6', 115200, timeout=.1)
    arduinoThread = threading.Thread(target=listenToArduino, args=())
    arduinoThread.daemon = True
    arduinoThread.start()
configureArduino()                                      # will reboot AVR based Arduinos
print("Waiting for Arduino")
while True:
    if not arduinoQueue.empty():
        message = arduinoQueue.get()
        if message == "START":
            break
        else:
            print("got unknown message from Arduino : " + message)
print("Arduino Ready")
print("Starting camera")
and you can try with this arduino code
const byte buttonPin = 3;
	pinMode(buttonPin, INPUT_PULLUP);
	Serial.println(F("setup done, waiting for button press"));
  while (digitalRead(buttonPin) == HIGH) yield(); // active wait until the button is pressed
  // notify that we are ready to start
  Serial.println(F("START"));
void loop() {}
Note that opening the Serial port from the python side will reboot your arduino (obviously the Serial monitor should not be open in the IDE)
what the python code does is to collect (in upper cap) all the lines sent by the Arduino in a queue and the main part of the code checks if something is in the queue and if so compare it to START. when START is found, you exit the infinite wait loop and proceed with the video acquisition
running the python script in a terminal
$$ python3 ./test.py
Waiting for Arduino
got unknown message from Arduino : SETUP DONE, WAITING FOR BUTTON PRESS
<<HERE I PRESSED THE BUTTON>>
Arduino Ready
Starting camera
    pass
while True:
    etc.
not sure this works on the Serial port
Neither am I but I was just demonstrating how to get past the empty while statement.
OK pass or continue would do indeed
oh thanks for your help! I am not sure if I understand everything tho.. I dont know where to put my actual code
Would it be like:
    message = b''
    while True:
            message = b''
        else:
                 message += incoming
    global arduino
while True:
        [HERE IS MY CODE]
break
        else:
don't indent, put your code at the same level where I had
āžœ
while True:
            break
        else:
[HERE IS YOUR CODE]
what exactly does F mean?
If I press the button. nothing happens, neither the data is send to python, nor the camera starts
it means store the string START in flash memory instead of SRAM as you don't have much of this.
the behavior is exactly as if you had typed Serial.println("START"); but with less memory used.
how is your button connected ? pin 3 -- button --- GND ?
right
okay, now it works that everything starts simultenously. However the code stops immediatly starting. Like I can see that the camera window pops up but then immediatly closes again
Post the code. You likely miss a while
Your initialization code goes here
while True:
    Your iterative code here
import serial
import cv2
import pyrealsense2
import csv
import time
import gsv8
import usb.core
import pyvisa
import usb.util
    message = b''
    while True:
            message = b''
        else:
                message += incoming
    global arduino
while True:
            break
        else:
#ser = serial.Serial('COM6', 9600, timeout=1)
# dev = gsv8.gsv8("COM9", 9600)  # load cell port
if ret == True:
camera = cv2.VideoCapture(3)
# image = cv2.cvtColor(frame_cam, cv2.COLOR_BGR2GRAY)
if ret_cam == True:
    cv2.imshow("Test cam", frame_cam)
# get arduino data(temp)---------------------------------
getData = arduino.readline()
V1 = 3.6
C1 = 1000
# entry = timestampStr + ',' + ','.join(readings) + ',' + force_x + ',' + force_y + ',' + force_z + '\n'
# entry = timestampStr + ',' + ','.join(readings) + ',' + voltage1 + ', ' + current1 + '\n'
print(entry)
    f.write(entry)
file.close()
pass
shouldnt this while True, make the loop go on? Or do I need another one
