Hi all!
I have a similar problem when trying to drive a smaller display 135x240 using the same ST7789 display controller and also using the Arduino_ST7789 fast library.
What I have found is that if you look into the Arduino_ST7789.cpp file you can see a lot of code written specifically for a 240x240 display. It even states its taken most of it from the adafruit_ST7789 equivalent library.
I've tried to copy the bits relating to the 135X240 but havent had any success just a black screen. Any ideas?
To make things a bit more different I'm using a xiao nrf52840 board. But it does work with the 240x240 display.
Below is the .cpp file
// Fast ST7789 IPS 240x240 SPI display library
// (c) 2019-20 by Pawel A. Hernik
#include "Arduino_ST7789_Fast_Xiao_DW.h"
#include <limits.h>
#include "pins_arduino.h"
#include "wiring_private.h"
#include <SPI.h>
//#include "Adafruit_ST77xx.h"//DW added as there was a sendcommand function that required it
// ST7789 commands
#define ST7789_NOP 0x00
#define ST7789_SWRESET 0x01
#define ST7789_SLPIN 0x10 // sleep on
#define ST7789_SLPOUT 0x11 // sleep off
#define ST7789_PTLON 0x12 // partial on
#define ST7789_NORON 0x13 // partial off
#define ST7789_INVOFF 0x20 // invert off
#define ST7789_INVON 0x21 // invert on
#define ST7789_DISPOFF 0x28 // display off
#define ST7789_DISPON 0x29 // display on
#define ST7789_IDMOFF 0x38 // idle off
#define ST7789_IDMON 0x39 // idle on
#define ST7789_CASET 0x2A
#define ST7789_RASET 0x2B
#define ST7789_RAMWR 0x2C
#define ST7789_RAMRD 0x2E
#define ST7789_COLMOD 0x3A
#define ST7789_MADCTL 0x36
#define ST7789_PTLAR 0x30 // partial start/end
#define ST7789_VSCRDEF 0x33 // SETSCROLLAREA
#define ST7789_VSCRSADD 0x37
#define ST7789_WRDISBV 0x51
#define ST7789_WRCTRLD 0x53
#define ST7789_WRCACE 0x55
#define ST7789_WRCABCMB 0x5e
#define ST7789_POWSAVE 0xbc
#define ST7789_DLPOFFSAVE 0xbd
// bits in MADCTL
#define ST7789_MADCTL_MY 0x80
#define ST7789_MADCTL_MX 0x40
#define ST7789_MADCTL_MV 0x20
#define ST7789_MADCTL_ML 0x10
#define ST7789_MADCTL_RGB 0x00
#define ST7789_135x240_XSTART 0
#define ST7789_135x240_YSTART 0
#define ST_CMD_DELAY 0x80
// Initialization commands for ST7789 240x240 1.3" IPS
// taken from Adafruit
////Direct From Adafruit
static const uint8_t PROGMEM
generic_st7789[] = { // Init commands for 7789 screens
9, // 9 commands in list:
ST77XX_SWRESET, ST_CMD_DELAY, // 1: Software reset, no args, w/delay
150, // ~150 ms delay
ST77XX_SLPOUT , ST_CMD_DELAY, // 2: Out of sleep mode, no args, w/delay
10, // 10 ms delay
ST77XX_COLMOD , 1+ST_CMD_DELAY, // 3: Set color mode, 1 arg + delay:
0x55, // 16-bit color
10, // 10 ms delay
ST77XX_MADCTL , 1, // 4: Mem access ctrl (directions), 1 arg:
0x08, // Row/col addr, bottom-top refresh
ST77XX_CASET , 4, // 5: Column addr set, 4 args, no delay:
0x00,
0, // XSTART = 0
0,
240, // XEND = 240
ST77XX_RASET , 4, // 6: Row addr set, 4 args, no delay:
0x00,
0, // YSTART = 0
320>>8,
320&0xFF, // YEND = 320
ST77XX_INVON , ST_CMD_DELAY, // 7: hack
10,
ST77XX_NORON , ST_CMD_DELAY, // 8: Normal display on, no args, w/delay
10, // 10 ms delay
ST77XX_DISPON , ST_CMD_DELAY, // 9: Main screen turn on, no args, delay
10 }; // 10 ms delay
static const uint8_t PROGMEM init_135x240[] = {
ST7789_SWRESET, ST_CMD_DELAY, // 1: Software reset, no args, w/delay
150, // 150 ms delay
ST7789_SLPOUT , ST_CMD_DELAY, // 2: Out of sleep mode, no args, w/delay
255, // 255 = 500 ms delay
ST7789_COLMOD , 1+ST_CMD_DELAY, // 3: Set color mode, 1 arg + delay:
10, // 10 ms delay
ST7789_MADCTL , 1, // 4: Memory access ctrl (directions), 1 arg:
0x00, // Row addr/col addr, bottom to top refresh
ST7789_CASET , 4, // 5: Column addr set, 4 args, no delay:
0x00, ST7789_135x240_XSTART, // XSTART = 0
(ST7789_TFTWIDTH+ST7789_135x240_XSTART) >> 8,
(ST7789_TFTWIDTH+ST7789_135x240_XSTART) & 0xFF, // XEND = 240
ST7789_RASET , 4, // 6: Row addr set, 4 args, no delay:
0x00, ST7789_135x240_YSTART, // YSTART = 0
(ST7789_TFTHEIGHT+ST7789_135x240_YSTART) >> 8,
(ST7789_TFTHEIGHT+ST7789_135x240_YSTART) & 0xFF, // YEND = 240
ST7789_INVON , ST_CMD_DELAY, // 7: Inversion ON
10,
ST7789_NORON , ST_CMD_DELAY, // 8: Normal display on, no args, w/delay
10, // 10 ms delay
ST7789_DISPON , ST_CMD_DELAY, // 9: Main screen turn on, no args, w/delay
20
#ifdef COMPATIBILITY_MODE
static SPISettings spiSettings;
#define SPI_START SPI.beginTransaction(spiSettings)
#define SPI_END SPI.endTransaction()
#else
#define SPI_START
#define SPI_END
#endif
// macros for fast DC and CS state changes
#define DC_DATA digitalWrite(dcPin, HIGH)
#define DC_COMMAND digitalWrite(dcPin, LOW)
#define CS_IDLE digitalWrite(csPin, HIGH)
#define CS_ACTIVE digitalWrite(csPin, LOW)
#else
#define DC_DATA *dcPort |= dcMask
#define DC_COMMAND *dcPort &= ~dcMask
#define CS_IDLE *csPort |= csMask
#define CS_ACTIVE *csPort &= ~csMask
#endif
// if CS always connected to the ground then don't do anything for better performance
#ifdef CS_ALWAYS_LOW
#define CS_IDLE
#define CS_ACTIVE
#endif
// speed test results:
// in AVR best performance mode -> about 6.9 Mbps
// in compatibility mode (SPI.transfer(c)) -> about 4 Mbps
inline void Arduino_ST7789::writeSPI(uint8_t c)
SPI.transfer(c);
#else
SPDR = c;
asm volatile("nop"); // 8 NOPs seem to be enough for 16MHz AVR @ DIV2 to avoid using while loop
asm volatile("rjmp .+0\n");
//while(!(SPSR & _BV(SPIF))) ;
#endif
// fast method to send multiple 16-bit values via SPI
inline void Arduino_ST7789::writeMulti(uint16_t color, uint16_t num)
while(num--) { SPI.transfer(color>>8); SPI.transfer(color); }
#else
asm volatile
"next:\n"
"out %[spdr],%[hi]\n"
"rjmp .+0\n" // wait 8*2+1 = 17 cycles
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"nop\n"
"out %[spdr],%[lo]\n"
"rjmp .+0\n" // wait 6*2+1 = 13 cycles + sbiw + brne
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"nop\n"
"sbiw %[num],1\n"
"brne next\n"
: [num] "+w" (num)
: [spdr] "I" (_SFR_IO_ADDR(SPDR)), [lo] "r" ((uint8_t)color), [hi] "r" ((uint8_t)(color>>8))
#endif
// fast method to send multiple 16-bit values from RAM via SPI
inline void Arduino_ST7789::copyMulti(uint8_t *img, uint16_t num)
while(num--) { SPI.transfer(*(img+1)); SPI.transfer(*(img+0)); img+=2; }
#else
uint8_t lo,hi;
asm volatile
"nextCopy:\n"
"ld %[hi],%a[img]+\n"
"ld %[lo],%a[img]+\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"nop\n"
"rjmp .+0\n" // wait 4*2+1 = 9 cycles + sbiw + brne + ld*2
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"nop\n"
"sbiw %[num],1\n"
"brne nextCopy\n"
: [num] "+w" (num)
: [spdr] "I" (_SFR_IO_ADDR(SPDR)), [img] "e" (img), [lo] "r" (lo), [hi] "r" (hi)
#endif
Arduino_ST7789::Arduino_ST7789(int8_t dc, int8_t rst, int8_t cs) : Adafruit_GFX(ST7789_TFTWIDTH, ST7789_TFTHEIGHT)
csPin = cs;
dcPin = dc;
rstPin = rst;
void Arduino_ST7789::init(uint16_t width, uint16_t height)
commonST7789Init(NULL); ///not sure
if (width == 135 && height == 240) {
// 1.14" display (centered, with odd size)
_rowstart = _rowstart2 = (int)((320 - height) / 2);
// This is the only device currently supported device that has different
// values for _colstart & _colstart2. You must ensure that the extra
// pixel lands in _colstart and not in _colstart2
_colstart = (int)((240 - width + 1) / 2);
_colstart2 = (int)((240 - width) / 2);
// windowWidth = width; DW//Seems adafruit use the var windowWidth for _width which what the fast library use
// windowHeight = height;
_width = width;
_height = height;
displayInit(init_135x240);
setRotation(2);
void Arduino_ST7789::writeCmd(uint8_t c)
DC_COMMAND;
CS_ACTIVE;
SPI_START;
writeSPI(c);
CS_IDLE;
SPI_END;
void Arduino_ST7789::writeData(uint8_t d8)
DC_DATA;
CS_ACTIVE;
SPI_START;
writeSPI(d8);
CS_IDLE;
SPI_END;
void Arduino_ST7789::writeData16(uint16_t d16)
DC_DATA;
CS_ACTIVE;
SPI_START;
writeMulti(d16,1);
CS_IDLE;
SPI_END;
void Arduino_ST7789::displayInit(const uint8_t *addr) //DW not present in adafruit
uint8_t numCommands, numArgs;
uint16_t ms;
numCommands = pgm_read_byte(addr++);
while(numCommands--) {
writeCmd(pgm_read_byte(addr++));
numArgs = pgm_read_byte(addr++);
ms = numArgs & ST_CMD_DELAY;
numArgs &= ~ST_CMD_DELAY;
while(numArgs--) writeData(pgm_read_byte(addr++));
if(ms) {
ms = pgm_read_byte(addr++);
if(ms==255) ms=500;
delay(ms);
// Initialization code common to all ST7789 displays
void Arduino_ST7789::commonST7789Init(const uint8_t *cmdList)
pinMode(dcPin, OUTPUT);
#ifndef CS_ALWAYS_LOW
pinMode(csPin, OUTPUT);
#endif
#ifndef COMPATIBILITY_MODE
dcPort = portOutputRegister(digitalPinToPort(dcPin));
dcMask = digitalPinToBitMask(dcPin);
csPort = portOutputRegister(digitalPinToPort(csPin));
csMask = digitalPinToBitMask(csPin);
#endif
#endif
// on AVR ST7789 works correctly in MODE2 and MODE3 but for STM32 only MODE3 seems to be working
SPI.begin();
spiSettings = SPISettings(4000000, MSBFIRST, SPI_MODE3); // 8000000 gives max speed on AVR 16MHz
#else
SPI.setClockDivider(SPI_CLOCK_DIV2);
SPI.setDataMode(SPI_MODE3);
#endif
CS_ACTIVE;
if(rstPin != -1) {
pinMode(rstPin, OUTPUT);
digitalWrite(rstPin, HIGH);
delay(50);
digitalWrite(rstPin, LOW);
delay(50);
delay(50);
if(cmdList) displayInit(cmdList);
/////DW Removed due to it not having the colstart2 needed for the 135x240. Substituted with the adafruit version
/*void Arduino_ST7789::setRotation(uint8_t m)
writeCmd(ST7789_MADCTL);
rotation = m & 3;
switch (rotation) {
case 0:
writeData(ST7789_MADCTL_MX | ST7789_MADCTL_MY | ST7789_MADCTL_RGB);
_xstart = _colstart;
_ystart = _rowstart;
case 1:
writeData(ST7789_MADCTL_MY | ST7789_MADCTL_MV | ST7789_MADCTL_RGB);
_ystart = _colstart;
_xstart = _rowstart;
case 2:
writeData(ST7789_MADCTL_RGB);
_xstart = 0;
_ystart = 0;
case 3:
writeData(ST7789_MADCTL_MX | ST7789_MADCTL_MV | ST7789_MADCTL_RGB);
_xstart = 0;
_ystart = 0;
void Arduino_ST7789::setRotation(uint8_t m) { //DW here I have issues with the windowWidth command which is not used by the arduino_ST7789_fast library.Remamed to Arduino_St7789. I've also commented it out these below as the equivalent lines of code did not contain it.
uint8_t madctl = 0;
rotation = m & 3; // can't be higher than 3
switch (rotation) {
case 0:
madctl = ST77XX_MADCTL_MX | ST77XX_MADCTL_MY | ST77XX_MADCTL_RGB;
// _width = windowWidth;
// _height = windowHeight;
case 1:
madctl = ST77XX_MADCTL_MY | ST77XX_MADCTL_MV | ST77XX_MADCTL_RGB;
_ystart = _colstart2;
// _height = windowWidth;
// _width = windowHeight;
case 2:
madctl = ST77XX_MADCTL_RGB;
_xstart = _colstart2;
_ystart = _rowstart2;
case 3:
madctl = ST77XX_MADCTL_MX | ST77XX_MADCTL_MV | ST77XX_MADCTL_RGB;
_xstart = _rowstart2;
//sendCommand(ST77XX_MADCTL, &madctl, 1); //DW this was not present in the arduino_ST7789_fast code. I added the ST78XX library to accomodate it
void Arduino_ST7789::setAddrWindow(uint16_t xs, uint16_t ys, uint16_t xe, uint16_t ye)
xs+=_xstart; xe+=_xstart;
ys+=_ystart; ye+=_ystart;
CS_ACTIVE;
SPI_START;
DC_COMMAND; writeSPI(ST7789_CASET);
DC_DATA;
writeSPI(xs >> 8); writeSPI(xs);
writeSPI(xe >> 8); writeSPI(xe);
DC_COMMAND; writeSPI(ST7789_RASET);
DC_DATA;
writeSPI(ys >> 8); writeSPI(ys);
writeSPI(ye >> 8); writeSPI(ye);
DC_COMMAND; writeSPI(ST7789_RAMWR);
DC_DATA;
// no CS_IDLE + SPI_END, DC_DATA to save memory
void Arduino_ST7789::pushColor(uint16_t color)
SPI_START;
//DC_DATA;
CS_ACTIVE;
writeSPI(color>>8); writeSPI(color);
CS_IDLE;
SPI_END;
void Arduino_ST7789::drawPixel(int16_t x, int16_t y, uint16_t color)
if(x<0 ||x>=_width || y<0 || y>=_height) return;
setAddrWindow(x,y,x+1,y+1);
asm volatile
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"rjmp .+0\n"
"nop\n"
//"rjmp .+0\n" // wait 6*2+1 = 13 cycles + sbiw + brne
//"rjmp .+0\n"
//"rjmp .+0\n"
//"rjmp .+0\n"
//"nop\n"
CS_IDLE;
SPI_END;
void Arduino_ST7789::drawFastVLine(int16_t x, int16_t y, int16_t h, uint16_t color)
if(x>=_width || y>=_height || h<=0) return;
if(y+h-1>=_height) h=_height-y;
setAddrWindow(x, y, x, y+h-1);
writeMulti(color,h);
CS_IDLE;
SPI_END;
void Arduino_ST7789::drawFastHLine(int16_t x, int16_t y, int16_t w, uint16_t color)
if(x>=_width || y>=_height || w<=0) return;
if(x+w-1>=_width) w=_width-x;
setAddrWindow(x, y, x+w-1, y);
writeMulti(color,w);
CS_IDLE;
SPI_END;
void Arduino_ST7789::fillScreen(uint16_t color)
fillRect(0, 0, _width, _height, color);
void Arduino_ST7789::fillRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color)
if(x>=_width || y>=_height || w<=0 || h<=0) return;
if(x+w-1>=_width) w=_width -x;
setAddrWindow(x, y, x+w-1, y+h-1);
writeMulti(color,w*h);
CS_IDLE;
SPI_END;
// draws image from RAM
void Arduino_ST7789::drawImage(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t *img16)
// all protections should be on the application side
if(w<=0 || h<=0) return; // left for compatibility
//if(x>=_width || y>=_height || w<=0 || h<=0) return;
//if(x+w-1>=_width) w=_width -x;
//if(y+h-1>=_height) h=_height-y;
copyMulti((uint8_t *)img16, w*h);
CS_IDLE;
SPI_END;
// draws image from flash (PROGMEM)
void Arduino_ST7789::drawImageF(int16_t x, int16_t y, int16_t w, int16_t h, const uint16_t *img16)
uint32_t num = (uint32_t)w*h;
uint16_t num16 = num>>3;
uint8_t *img = (uint8_t *)img16;
while(num16--) {
writeSPI(pgm_read_byte(img+1)); writeSPI(pgm_read_byte(img+0)); img+=2;
uint8_t num8 = num & 0x7;
while(num8--) { writeSPI(pgm_read_byte(img+1)); writeSPI(pgm_read_byte(img+0)); img+=2; }
CS_IDLE;
SPI_END;
// Pass 8-bit (each) R,G,B, get back 16-bit packed color
uint16_t Arduino_ST7789::Color565(uint8_t r, uint8_t g, uint8_t b)
return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | (b >> 3);
void Arduino_ST7789::invertDisplay(boolean mode)
writeCmd(!mode ? ST7789_INVON : ST7789_INVOFF); // modes inverted?
void Arduino_ST7789::partialDisplay(boolean mode)
writeCmd(mode ? ST7789_PTLON : ST7789_NORON);
void Arduino_ST7789::sleepDisplay(boolean mode)
writeCmd(mode ? ST7789_SLPIN : ST7789_SLPOUT);
delay(5);
void Arduino_ST7789::enableDisplay(boolean mode)
writeCmd(mode ? ST7789_DISPON : ST7789_DISPOFF);
void Arduino_ST7789::idleDisplay(boolean mode)
writeCmd(mode ? ST7789_IDMON : ST7789_IDMOFF);
void Arduino_ST7789::resetDisplay()
writeCmd(ST7789_SWRESET);
delay(5);
void Arduino_ST7789::setScrollArea(uint16_t tfa, uint16_t bfa)
uint16_t vsa = 320-tfa-bfa; // ST7789 320x240 VRAM
writeCmd(ST7789_VSCRDEF);
writeData16(tfa);
writeData16(vsa);
writeData16(bfa);
void Arduino_ST7789::setScroll(uint16_t vsp)
writeCmd(ST7789_VSCRSADD);
writeData16(vsp);
void Arduino_ST7789::setPartArea(uint16_t sr, uint16_t er)
writeCmd(ST7789_PTLAR);
writeData16(sr);
writeData16(er);
// doesn't work
void Arduino_ST7789::setBrightness(uint8_t br)
//writeCmd(ST7789_WRCACE);
//writeData(0xb1); // 80,90,b0, or 00,01,02,03
//writeCmd(ST7789_WRCABCMB);
//writeData(120);
//BCTRL=0x20, dd=0x08, bl=0x04
int val = 0x04;
writeCmd(ST7789_WRCTRLD);
writeData(val);
writeCmd(ST7789_WRDISBV);
writeData(br);
// 0 - off
// 1 - idle
// 2 - normal
// 4 - display off
void Arduino_ST7789::powerSave(uint8_t mode)
if(mode==0) {
writeCmd(ST7789_POWSAVE);
writeData(0xec|3);
writeCmd(ST7789_DLPOFFSAVE);
writeData(0xff);
return;
int is = (mode&1) ? 0 : 1;
int ns = (mode&2) ? 0 : 2;
writeData(0xec|ns|is);
if(mode&4) {
writeData(0xfe);
// Input a value 0 to 511 (85*6) to get a color value.
// The colours are a transition R - Y - G - C - B - M - R.
void Arduino_ST7789::rgbWheel(int idx, uint8_t *_r, uint8_t *_g, uint8_t *_b)
idx &= 0x1ff;
if(idx < 85) { // R->Y
*_r = 255; *_g = idx * 3; *_b = 0;
return;
} else if(idx < 85*2) { // Y->G
idx -= 85*1;
*_r = 255 - idx * 3; *_g = 255; *_b = 0;
return;
} else if(idx < 85*3) { // G->C
idx -= 85*2;
*_r = 0; *_g = 255; *_b = idx * 3;
return;
} else if(idx < 85*4) { // C->B
idx -= 85*3;
*_r = 0; *_g = 255 - idx * 3; *_b = 255;
return;
} else if(idx < 85*5) { // B->M
idx -= 85*4;
*_r = idx * 3; *_g = 0; *_b = 255;
return;
} else { // M->R
idx -= 85*5;
*_r = 255; *_g = 0; *_b = 255 - idx * 3;
return;
uint16_t Arduino_ST7789::rgbWheel(int idx)
uint8_t r,g,b;
rgbWheel(idx, &r,&g,&b);
return RGBto565(r,g,b);
// ------------------------------------------------type or paste code here
