How to sync Stepsequencer Untztrument (trellis 4x4 adafruit) with Tempo of Ableton Live or Other Daw?
Hello
i recently made a custom stepsequencer 16 with 4 Trellis Leds/Buttons PAD
The code is based on UNTZtrument : Trellis MIDI Instrument.
In that code we have a rotary encoder to set tempo
And i wish know how to set the Variable Tempo with USB MIDI Clock (ableton Tempo) to synchronize the stepsequencer with ableton or an other DAW
Any way to begin will be apprecieted to do that
// Simple UNTZtrument MIDI step sequencer.
// Requires an Arduino Leonardo w/TeeOnArdu config (or a PJRC Teensy),
// software on host computer for synth or to route to other devices.
#include <Wire.h>
#include <Adafruit_Trellis.h>
#include <Adafruit_UNTZtrument.h>
#include "MIDIUSB.h"
#define LED 13 // Pin for heartbeat LED (shows code is working)
#ifndef HELLA
// A standard UNTZtrument has four Trellises in a 2x2 arrangement
// (8x8 buttons total).  addr[] is the I2C address of the upper left,
// upper right, lower left and lower right matrices, respectively,
// assuming an upright orientation, i.e. labels on board are in the
// normal reading direction.
Adafruit_Trellis     T[4];
Adafruit_UNTZtrument untztrument(&T[0], &T[1], &T[2], &T[3]);
const uint8_t        addr[] = { 0x70, 0x71, 0x72, 0x73 };
#else
// A HELLA UNTZtrument has eight Trellis boards...
Adafruit_Trellis     T[8];
Adafruit_UNTZtrument untztrument(&T[0], &T[1], &T[2], &T[3],
                                 &T[4], &T[5], &T[6], &T[7]);
const uint8_t        addr[] = { 0x70, 0x71, 0x72, 0x73,
                                0x74, 0x75, 0x76, 0x77 };
#endif // HELLA
#define WIDTH     ((sizeof(T) / sizeof(T[0])) * 2)
#define N_BUTTONS ((sizeof(T) / sizeof(T[0])) * 16)
// Encoder on pins 4,5 sets tempo.  Optional, not present in
// standard UNTZtrument, but won't affect things if unconnected.
enc e(4, 5);
uint8_t       grid[WIDTH];                 // Sequencer state
uint8_t       heart        = 0,            // Heartbeat LED counter
              col          = WIDTH-1;      // Current column
unsigned int  bpm          = 240;          // Tempo
unsigned long beatInterval = 60000L / bpm, // ms/beat
              prevBeatTime = 0L,           // Column step timer
              prevReadTime = 0L;           // Keypad polling timer
// The note[] and channel[] tables are the MIDI note and channel numbers
// for to each row (top to bottom); they're specific to this application.
// bitmask[] is for efficient reading/writing bits to the grid[] array.
static const uint8_t PROGMEM
  note[8]    = {  72, 71, 69, 67, 65, 64, 62,  60 },
  channel[8] = {   1,  1,  1,  1,  1,  1,  1,   1 },
  bitmask[8] = {   1,  2,  4,  8, 16, 32, 64, 128 };
  pinMode(LED, OUTPUT);
#ifndef HELLA
  untztrument.begin(addr[0], addr[1], addr[2], addr[3]);
#else
  untztrument.begin(addr[0], addr[1], addr[2], addr[3],
                    addr[4], addr[5], addr[6], addr[7]);
#endif // HELLA
  // Default Arduino I2C speed is 100 KHz, but the HT16K33 supports
  // 400 KHz.  We can force this for faster read & refresh, but may
  // break compatibility with other I2C devices...so be prepared to
  // comment this out, or save & restore value as needed.
#ifdef ARDUINO_ARCH_SAMD
  Wire.setClock(400000L);
#endif
#ifdef __AVR__
  TWBR = 12; // 400 KHz I2C on 16 MHz AVR
#endif
  untztrument.clear();
  untztrument.writeDisplay();
  memset(grid, 0, sizeof(grid));
  enc::begin();                     // Initialize all encoder pins
  e.setBounds(60 * 4, 480 * 4 + 3); // Set tempo limits
  e.setValue(bpm * 4);              // *4's for encoder detents
void noteOn(byte channel, byte pitch, byte velocity) {
  midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
  MidiUSB.sendMIDI(noteOn);
  MidiUSB.flush();
void noteOff(byte channel, byte pitch, byte velocity) {
  midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
  MidiUSB.sendMIDI(noteOff);
  MidiUSB.flush();
// Turn on (or off) one column of the display
void line(uint8_t x, boolean set) {
  for(uint8_t mask=1, y=0; y<8; y++, mask <<= 1) {
    uint8_t i = untztrument.xy2i(x, y);
    if(set || (grid[x] & mask)) untztrument.setLED(i);
    else                        untztrument.clrLED(i);
  uint8_t       mask;
  boolean       refresh = false;
  unsigned long t       = millis();
  enc::poll(); // Read encoder(s)
  if((t - prevReadTime) >= 20L) { // 20ms = min Trellis poll time
    if(untztrument.readSwitches()) { // Button state change?
      for(uint8_t i=0; i<N_BUTTONS; i++) { // For each button...
        uint8_t x, y;
        untztrument.i2xy(i, &x, &y);
        mask = pgm_read_byte(&bitmask[y]);
        if(untztrument.justPressed(i)) {
          if(grid[x] & mask) { // Already set?  Turn off...
            grid[x] &= ~mask;
            noteOff(pgm_read_byte(&channel[y]), pgm_read_byte(&note[y]), 127);
          } else { // Turn on
            grid[x] |= mask;
          refresh = true;
    prevReadTime = t;
    digitalWrite(LED, ++heart & 32); // Blink = alive
  if((t - prevBeatTime) >= beatInterval) { // Next beat?
    // Turn off old column
    line(col, false);
    for(uint8_t row=0, mask=1; row<8; row++, mask <<= 1) {
      if(grid[col] & mask) {
        noteOff(pgm_read_byte(&channel[row]), pgm_read_byte(&note[row]), 127);
    // Advance column counter, wrap around
    if(++col >= WIDTH) col = 0;
    // Turn on new column
    line(col, true);
          noteOn(pgm_read_byte(&channel[row]), pgm_read_byte(&note[row]), 127);
    prevBeatTime = t;
    refresh      = true;
    bpm          = e.getValue() / 4; // Div for encoder detents
    beatInterval = 60000L / bpm;
  if(refresh) untztrument.writeDisplay();
Hi
What language is your topic title in?
16 Steps Sequencer Adafruit Trellis Modified UNTZtrument from Adafruit
Any idea?
I Tried this to generate a Midi Clock Arduino to Ableton
#include <uClock.h>
// MIDI clock, start and stop byte definitions - based on MIDI 1.0 Standards.
#define MIDI_CLOCK 0xF8
#define MIDI_START 0xFA
#define MIDI_STOP  0xFC
// The callback function wich will be called by Clock each Pulse of 96PPQN clock resolution.
void ClockOut96PPQN(uint32_t tick) {
  // Send MIDI_CLOCK to external gears
  Serial.write(MIDI_CLOCK);
// The callback function wich will be called when clock starts by using Clock.start() method.
void onClockStart() {
  Serial.write(MIDI_START);
// The callback function wich will be called when clock stops by using Clock.stop() method.
void onClockStop() {
  Serial.write(MIDI_STOP);
  // Initialize serial communication at 31250 bits per second, the default MIDI serial speed communication:
  // Inits the clock
  uClock.init();
  // Set the callback function for the clock output to send MIDI Sync message.
  uClock.setClock96PPQNOutput(ClockOut96PPQN);
  // Set the callback function for MIDI Start and Stop messages.
  uClock.setOnClockStartOutput(onClockStart);
  uClock.setOnClockStopOutput(onClockStop);
  // Set the clock BPM to 126 BPM
  uClock.setTempo(170);
  // Starts the clock, tick-tac-tick-tac...
  uClock.start();
// Do it whatever to interface with Clock.stop(), Clock.start(), Clock.setTempo() and integrate your environment...
Did it work?
No it's just for test to have a MIDI CLOCK Generate with Arduino
In ableton when i click on External Tempo we have the TEMPO set in ;
So tempo is read by Ableton It work in on direction Arduino => Midi Clock => TEMPO => Ableton
My project must work in the other direction Ableton => TEMPO => Midi Clock => Arduino
I Wish to sync a stepsequencer with TEMPO of Ableton or how read the midi clock send by USBMIDI.
Here the code i use and modified
